For those members wanting to fight , please read this.
We have had alot of very open disagreeing here lately. If you guys wish to fight, go to the group section on your profile page, start a group, and there you can fight away from everyone.
Anyone who wants a Mod to look over there fighting you can go to my profile page and use my group section to fight in!!!!!!!
If none of this works for you please PM admin and requst a fight club(Can we call it BuckBilly's B.S. Lounge?). Thank you.
  • 5 months later...
  • Admin unpinned this topic
    • By dlgg7
      I've had this for probably 15 years. It ran great till 4-5 years ago, mainly riding the grandkids around our fields, till it wouldn't start. It sat for a couple of years till I bought a new battery, but couldn't get it to even hit, so rebuilt the carb, put on a new fuel pump, but no go, so it's sat. Several days ago, charged battery, cranked over and it started??? OK, idles good, but won't rev up, so emptied gas tank, flushed out and filled w/good 93 octane, pulled pump line from carb and have good full line of fuel cranking over. New spark plug, good spark, old one black BAD! Oil change, adjusted valves, no difference. Pulled carb and took apart and cleaned, didn't find any clogs or crusted up inside. Now I've had the carb back off probably 6 times checking, double checking anything I can think of. No gas blowing back in air box. It idles good, can increase throttle up some then starts popping and dropping rpms off and if I don't let off the throttle, it'll die. I've read for 3 days now MECHs and RANDY walking several thru tracing the same problem, tried MOST of the direction given. ???
    • By Seriousbird
      1992 Suzuki kingquad 300 with 17000 kms.
      New intake boot same old problem. Starts and Idles perfect, wont take any % of throttle. Same tune i had as when it got flooded with water.
      All i did since then:
      Cleaned the top and bottom of the carb and jets.
      Swapped different plastics onto it.
      Rebuilt the starter.
      Added another ground. (Since removed)
      Extended the positive terminal so it can fit without strain.
      Added battery.
      Swapped carb diaphragm off of another. (No holes)
      Did a temporary oil cooler delete.
      Flushed and replaced the oil.
      Just added a brand new intake boot & gasket....
      Had it running perfectly just days ago minutes after i siliconed the intake gasket. It has since melted away from gas i assume. Didn't touch it for 4 days went to go for a ride and bogged and bogged. Replaced the gasket and intake boot to no avail, so i really don't know what's going on now.
      The spark plug is dry carbony but it's the same tune as before..
      Has good fuel flow in the line, fuel is new.
      I was testing spark yesterday and it was bright orange. And it eventually went back to its white, Not blue by any means.
      Before i replaced the intake boot it would take tension on the throttle and you would get 2000 rpm max before it bogged..
      Since i replaced it, it won't take any at all. Spraying flammable liquids into the carburetor had the same bog result. I tried spraying said flammable liquids around the head boot seal and didn't notice any difference. I didn't try for too long.
      boot to head is tightened as much as i could with a screwdriver + less than a quarter turn with a ratchet.
      Previous silicone very possibly could have fell into the combustion chamber and did something there??...
      No difference with any choke, with or without airbox boot, pressurizing the fuel tank, battery disconnected.. there was a point where i left choke on and had the air filter that came with it on and it flooded the whole airbox with fuel, That was when i was building compression because i lost all of it during the flushing process. (It's back now)
      Im lost! This thing was perfect until i got water in the oil and flushed everything and what not. Its only been less than a week since then so theres no chance the fuel went bad.
      Snapchat-1004857443.mp4  Ps the switch is a neutral safety switch bybass. It really hates itself with the switch off. It makes a knocking noise and idles with a surge. Is perfect with a battery connected off and on but without a battery it has to be on..
    • By JohnKramer
      I replace everything involving fuel and it still won’t work.
      Out on the trail, visibility is everything. When you’re riding, you need to be able to see every potential obstacle well in advance, and sometimes, that includes things behind or beside your vehicle. On your own private property, sideview and rearview mirrors are a clear value-add, helping you avoid some of the entirely preventable accidents that can pop up when you’re driving in Reverse. On public trails, those mirrors are an absolute necessity, drastically helping mitigate the risk of vehicle-to-vehicle collisions and prevent bodily injuries.
      That’s why Kemimoto, a market leader in the design and manufacture of ATV and UTV accessories, has devoted so much focus to UTV mirrors over the past decade, in addition to accessories like saddlebags, seat bags, whip lights, and more. When the company was founded back in 2011, there weren’t any readily available, affordable off-road mirrors for Side-by-Sides on the market that were much good for anything other than showing riders the rears of their own vehicles. So, the company’s founders took up the challenge, setting out to create their own side mirrors to provide fellow ORV enthusiasts with a better view of their blind spots.
      Mirrors have been Kemimoto’s hottest-selling products ever since.
      Today, Kemimoto has a staggeringly impressive collection of sideview and rearview mirrors for UTVs, ATVs, and bikes on offer, with nearly a hundred unique mirror packages on sale through the official Kemimoto website. Kemimoto makes mirrors to suit any need and any budget. Many of them are best-sellers in their respective categories, and for very good reason: as a direct-to-consumer brand, products are marketed, sold, and delivered to customers directly by Kemimoto. That extra efficiency allows the company to price its ATV and UTV accessories more effectively, and sell high-quality mirrors and other products while keeping prices extremely affordable.
      Equally important, Kemimoto’s ORV mirrors are just plain good. Design, development, and engineering all take place in-house, and the company even holds a few patents for some of its innovations. They have their own laboratory for product testing, to ensure that every mirror that wears the Kemimoto name is tough enough to go the distance. The mirrors are designed for beginners and professionals alike, with ridiculously simple install procedures that typically require a hand tool or two and just a few minutes of your time to set up. They are made to suit the overall aesthetics and performance requirements of the vehicles they are designed for.
      As an example, let’s take a look at a pair of Kemimoto’s lighted side mirrors designed for Sport Side-by-Sides. As the name implies, Kemimoto has built two levels of lighting into each of the side mirrors. You can fire up one or both of the lights in each mirror. And with an angle of illumination of 195 degrees, you can see exactly where you are going.
      Additionally, these mirrors boast shatterproof tempered glass, which helps protect the driver and passengers in case of an impact. They also feature a breakaway design, so they will fold up if you get a little too close to a tree or any other obstacle rather than snap right off. When it comes to construction, Kemimoto made the shell out of a high-quality ABS, while and the frame and bracket are built out of aluminum.
      Of course, Kemimoto is more than just mirrors. The brand also produces and sells its own saddlebags for motorcycles, seat bags for ATVs, backpacks, roll cage cargo organizers, and other storage accessories. They also manufacture high-quality whip lights and mounts, UTV cupholders, dome lights, windshields, vehicle covers, and even some riding gear. But high-quality, fairly priced ORV mirrors will always be the company’s specialty.
    • By spock58
      I was reading another forum recently about fuel leaks and possibility of fire happening. Reminded me of an incident I had a few years ago while working at a Can Am dealership. The quad was a stolen & recovered Outlander 650 that had been tampered with. These quads have an electronic safety system, similar to their DESS system on the sleds. You cannot bypass the key switch and get spark without a computer with factory software. Anyway, I was trying to determine what was damaged since the thief had attempted to hot wire various electronic parts. I got all the extra wires removed and things looked back to stock. Pulled the spark plugs and was going to check for ignition and if the starter still worked. Well, they both worked alright and guess what - the cylinder was flooded with fuel! Instant flames with gas spraying all over...great!! I managed to use my hands to put out the fire, good thing I had on gloves (but choked they were ruined of course, haha). Seems it's possible to flood an engine with efi when you put power straight to the injectors, doh! As in much of life, you cannot take things for granted (I'd only seen carbs flood like that). And even though it had spark, the quad still needed a new ECM to run - that part alone was $1200. So lets hear your stories, crazy stuff happens every day I'm sure.
