Theses look really cool. I can't wait to see who they have racing for them in MX. Adam McGill has been doing pretty good in XC. Bot this may be what you need dude.
KTM 2009 450SX / 505SX Model Preview | ATV Illustrated
yea the 2009's are sweet. Here is some more info on them:
KTM Launches 2009 450 SX and 505 SX at RedBud - A premium machine at a premium price - ATV at Off-Road.com
I heard they are not going to have an "Official" Factory MX team for 2009 although they may support a team through a dealer or something.
    • By shorty
    • By johndeerefarm
      Is there any way to mod an Outlaw 50 to increase the speed? The size is perfect just would like a little more top end speed. Thanks
      I bought this Eiger about a year ago it has been my runner while i worked on my other projects, except today it wouldnt crank, i suspect it is the  petcock not letting fuel through. When i bought it it had a multitude of problems, but i just ignored those and rode it any way, put it on the back burner while i worked on my other projects with more serious problems, like stuck engine ,wiring harness ripped out, and wheels locked up. Got those all sorted out and since it wouldnt crank today decided it was time to refine this one. When i got it it had a bad Non OEM carb replaced it with a cheap aftermarket until i could find a descent priced OEM to rebuild, and have been riding it ever since. It also had a bad petcock, would only run on prime, neutral light didnt work, no brakes, which are a luxury anyway, but as im getting older luxurys are nice to have, so i guess i will fix those. I paid a little more for this one, $800 but he wanted $1500, because it ran and moved and most things seemed to work, and it didnt smoke, even with the bad carb. Generally 500 is my limit for a non runner, since this one ran i upped my limit a little. So i got it out of the shed before the mice got in it for the winter and started going over it today.
      I would never buy a new camouflaged one because of what you see here, and it almost stopped me from buying this one, but it is what it is, not much i can do for that now, they did look nice when new, i am toying with the idea of replacing the plastics while i can still get them, but am not there yet, expensive.
      I think the snorkel has got to go its not hooked up anyway. Looks like a perfect mouse house.
    • By Fowler175
      Hi everyone!  I am rebuilding my father's 2022 Sportsman 450HO that caught fire and wrecked all of the body and melted much of the wiring harness. I was able to source a used harness to splice in, but it's missing the wires and connectors going to the left side controls (Start/stop, headlight hi/lo & reverse overide). I haven't been able to find individual part #'s for these plugs/pigtails, Polaris only lists the entire harness for a huge amount $$$. At 72 yrs old, the last thing he needs is to spend all his money on a quad he's only had less than a year, lol. Does anyone know of the part #'s for these, or an aftermarket source?  Thanks!
    • By Thegrizz
      So, I just bought this quad off a acquaintance of mine… anyways, it’s missing the airbox which I’m trying to purchase if I could only figure out the year and what model of lt230 it is due to having only 9 visible digits for a vin…guy said he had the title at one point and lost it when he moved houses after the flood of 08 in Iowa….I just desperately need to know what model this thing is so I can start getting to work on it….it does run after a good carb cleaning….I’m having trouble getting it to idle though due to essentially just having a rigged up air filter with no airbox on the bike…I’ve sanded down the plastics and it looks like the original color was orange and the seat I believe is either from a different Suzuki or it’s been painted gold and black? The plastic nose part is originally black…it has the lever for reverse by the sprocket it has a pull string to start and I think originally it has electric start as well….idk I’ve had to bypass and use a screwdriver on the starter Solenoid to get it to start …someone has definitely done some rigging with the wiring as well.but if anyone has any clue what I need to look for to identify the year and actual model so I can get the right stuff. I’d appreciate it.
