What do you think caused this?
By mga
By davefrombc
This video of BMW engines being manufactured in China very well illustrates where all the unskilled repetitive jobs have gone, and why they're not coming back in America or anywhere else. What BMW has done in China is being repeated by every industry everywhere. If it can be automated, it will be and except for a handful of operators the only people employed by those businesses will be tradesmen maintaining the robots.
Education and trades training is far more important today than it has ever been.
By kfwa
Hello
I have an '86 LT230s.
recently I put a new top end in. Took it out for a test drive after the rebuild and the screw holding the cam chain tensioner was loose and fell out. When I stopped the motor I couldn't start again. Fearing the cam chain jumped the timing I pushed it back, reset the timing by using a screwdriver in the spark plug hole to determine the top end.
Bike still wouldn't start where in the past it would start on the first kick. I was pretty confident I hadn't screwed up the timing so I pulled the spark plug to spray some starting fluid in the chamber and noticed the spark plug wasn't getting any spark.
I tested the ground, the usual suspects. I had a donor bike so I replaced the coil and the CDI. Still nospark.
So here is where is gets interesting.
I take the stator cover off, wipe down the flywheel and coils and I guess what you'd call the magneto because they all had a light layer of oil on them. In order to take the stator cover off of course I had to drain the oil. So after wiping it down, putting the stator cover back on I get a strong spark.
In my haste, I start the motor and let it run for about 20 seconds before I realize I didn't put the oil back in.
I put the oil back in...and you guessed it - now I'm back to having no spark.
I'm trying to figure out if I need to replace something - clearly I can't run it without oil.
any ideas would be welcome.
By mywifeknowseverythin
Interesting statistic
"A 2006 study found that the average American walks about 900 miles a year.
Another study found that Americans drink an average of 22 gallons of beer a year.
That means, on average, Americans get about 41 miles per gallon."
Not bad!
