The last couple of years, the Taiwanese based company, Unison has been working on a 450 racer. They are getting ready to release them. They actually teamed up with a company called Metrakit. Metrakit is a Barcelona based company that has been huge in the GT mini racing. Those 2 along with Fuji Heavy Industries, developed their racer. The motor was built in Japan by Fuji, which is the parent company of Suburu. The powerhouse is a 448cc DOHC 4 valve, liquid cooled, with a 36mm carb. It has a 5 speed manual with reverse, 520 O-ring final drive. Dual A-arms up front with preload adjustable piggyback shocks with 8" of travel. The rear is solid axle with rebound adjustable gas shock. The biggest problem I see with it is the weight, it comes in at 445lbs. DRY WEIGHT!!! It has a very similar look to the KTM in the hood and front fenders. The fenders are removable for the shaved look. Comes with nerfs, doesn't look to bad. The quality tends to be shakey at best with these off brands, I have a feeling that quality levels have been stepped up for this one. Seeing how they worked with 2 other companies that would not want to hurt their own name by releasing poorly made equipment. Unison, Fuji (parent of Suburu) and Metrakit really stepped up the off brand quad market this year.
  • 2 years later...
    • By Asand211
      I've got a 1995 220 Bayou and the electric start does not work.  When I got it the machine was pretty rough but I was told it ran less than a year ago.  The key switch had been cut off and wires  twisted after the key was lost.  I bought a new ignition switch and repaired the wiring and it is working correctly.  It is in neutral and the neutral light is on when the key is turned on but I get nothing when pressing the start button.  I verified there is no voltage going to the starter from the solenoid.  The fuse in the solenoid is good.  Something I found that is odd is that I get positive voltage(12 volts) to the brown, black, and white wires that run into the solenoid when the key is on.  That doesn't make sense to me but I could be wrong.  I would appreciate any help I can get. Thank you in advance.
    • By TravisCr
      I bought this from a buddy to plow snow up in the North Eastern Washington- its been getting oil in the water and I've been changing the oil often and adding collant as necessary-
      I've taken the stator cover off and I'm looking at the Oil Seal and water pump seal and they look good- Although I've ordered a factory oil Seal I'm looking at putting it in this afternoon-
      I don't have the factory service manual- am I suppose to Add RTV to the Stator cover Gasket? I've seen some folks suggest grease other suggest RTV?
      Any suggestions here- I'm trying to reassemble it tonight- I looked at downloading the manual but need to get up to 10 posts firsts it looks like-
      I appreciate any suggestions- normally I'm a jeep and honda dirt bike guy- but  I got a good deal on the quad and a plow so I went for it
      Its got a bit over 3K and runs pretty good- but I've had her tore apart for 3 weeks to figure out the oil in the coolant issue.
    • By Werewolf
      Oil is getting in the air box from crankcase vent tube, I put the two hoses that go to the air box together then something started to smoke on the front of the engine. There is a filter? In the line I blew that out.
    • By Clydaho
      Any other ideas?
      Thanks for any help,
      Clyde
    • By p5200
      The studs in the sprocket hub are stripped out. The hub is probably walloed out also. Probably will have to have a new sprocket hub. I doubt I have the ability nor the tools needed for this job. Thanks for all suggestions/opinions!
      20240225_155255.mp4   20240225_155255.mp4 20240225_155255.mp4 20240225_155255.mp4
