Unison VNX 450R
The last couple of years, the Taiwanese based company, Unison has been working on a 450 racer. They are getting ready to release them. They actually teamed up with a company called Metrakit. Metrakit is a Barcelona based company that has been huge in the GT mini racing. Those 2 along with Fuji Heavy Industries, developed their racer. The motor was built in Japan by Fuji, which is the parent company of Suburu. The powerhouse is a 448cc DOHC 4 valve, liquid cooled, with a 36mm carb. It has a 5 speed manual with reverse, 520 O-ring final drive. Dual A-arms up front with preload adjustable piggyback shocks with 8" of travel. The rear is solid axle with rebound adjustable gas shock. The biggest problem I see with it is the weight, it comes in at 445lbs. DRY WEIGHT!!! It has a very similar look to the KTM in the hood and front fenders. The fenders are removable for the shaved look. Comes with nerfs, doesn't look to bad. The quality tends to be shakey at best with these off brands, I have a feeling that quality levels have been stepped up for this one. Seeing how they worked with 2 other companies that would not want to hurt their own name by releasing poorly made equipment. Unison, Fuji (parent of Suburu) and Metrakit really stepped up the off brand quad market this year.
  • 2 years later...
    • By Clydaho
      Any other ideas?
      Thanks for any help,
      Clyde
    • By mehim
      Hi everyone.
    • By p5200
      The studs in the sprocket hub are stripped out. The hub is probably walloed out also. Probably will have to have a new sprocket hub. I doubt I have the ability nor the tools needed for this job. Thanks for all suggestions/opinions!
      20240225_155255.mp4   20240225_155255.mp4 20240225_155255.mp4 20240225_155255.mp4
      My Yamaha Big Bear shifts through all the gears good, goes into reverse smoothly, but when i go to get out of reverse it takes a lot of effort to get it back to first gear, and even then it does not go very smoothly, have to pull up on the pedal really hard, anyone else ever had this problem. Any ideas would be greatly appreciated.
    • By Werewolf
