just got a Honda ATV200ES today for free and it seem to be in good shape! The last owner said it wasnt getting a spark. There is no battery in it yet (does it need one to spark?) Where do i need to start on this thing and is there anywhere i can find the specs? ie..compression valvel clearence ect. Any info on this would be great, thanks
1984 was the First and only yr for the 200ES..Went to the 250ES in 85..Nice to have Shaft drive with reverse....
The battery is only there for the ES....You have the Back up pull Start.....I do think though you have to have something there to Complete the Circuit for it to get spark....So,,,,New battery might be needed if you dont have anything there....
Here is a wiring Diagram
ATC200ESx84.jpg?t=1223734989
Frame number JH3TB0554EC300001~
Engine number TB05E-6000001~
Engine type 4 stroke, Air cooled
Displacement 192 cc
Bore x Stroke 65 x 57.8 mm
Compression ratio 7.8 to 1
Compression 142 - 170 psi
Transmission speeds 5 speed with dual range & Reverse
Clutch Type Automatic
Oil Capacity 1.43 Qt
Carburetion 22 mm Keihin
Starting system Electric with recoil backup
Fuel capacity 3gal with .03 reserve
Wheelbase 48.4 in.
Overall Length 72.8 in.
Overall Width 42.1 in.
Ground Clearance 5.9 in.
Seat height 27 in.
Front tire 25 x 12 x 9
Rear tires 25 x 12 x 9
Front suspension Telescopic Forks
Rear suspension none
Front brake Drum
Rear brake Drum
Final drive Shaft
Dry weight 375 lbs
Approx. retail new $1,848.00
free is a good price! REM to change the oil cuz most folks never check them, like lawnmowers.....
clean, fresh oil will make it happy and bring the compression up.
Typically Honda machines need a battery to run, I suggest you talk more with MYKE as he sounds very familiar with that model.
!!WELCOME WHEELER!! I'll be happy to help! I have 3, cant compete with MYKE.......;p
WOW thanks for the response! wiring diagramed saved to the comuter for refernce. Put a dead battery in and checked voltage from the stator that was good, chaecked all the way to the coil in and got good voltage but nothing out( pluged in a coil off a Isuzu Trooper and got volage out ) oredered a new coil for $44.00 bucks will be in soon I'll let ya'll know about the out come and try to post some picks.
This is a great forum thanks all for your help.
    • By Mister907
