By quadcrazy
QUADCRAZY NEEDS YOU!
By HoldenBoy
Hi all,
By mikeexplorer
By Whiterabbit
Hey all, from SW Virginia here. I just picked up a '01 Bombardier Quest 650 on the cheap (seller couldn't get it to start). After correctly plumbing the fuel pump (new pump the prior owner installed but had the hoses going backwards lol) and cleaning the carb and fuel tank, repaired all the batt - and batt+ connections she lives!! I had swore to the wife unit I wouldn't be dragging another "project" home but I couldn't pass it up, it had new tires, new starter, new fuel pump and low hrs. All's good after she took it for a ride! 😆 It rides like a tank, very stable and tons of power.
By WyattLemke25
Having problems with the battery draining while riding. It has a new battery, it does have eps, a lightbar and a winch. Can ride it for an hour or more just fine, but eventually the battery runs down to the point it can't keep up with fuel injection and it'll sputter, limp, and die. It also throws codes for the throttle position sensor. I'm not sure if that is related or not. Any ideas?
