By Callaway
By mattgoodwin
I'm repairing a 96 Timberwolf 2x4. Many years ago a dog chewed the wires that go from stator to the rectifier/regulator, and I've had to use the pull start ever since. Ive since lost the plug for the stator and on the wiring harness side. I'm ordering a new stator that will also come with the female plug that I need to fix it on the wiring harness side, but I have no clue in what position to put those 3 white wires(ones I'm holding with electrical tape on them) back into the new plug. Since they're all the same color, does it matter? Any info on this or pictures anyone has of their own will be very much appreciated.
By McG75
Sorry I suck at these forums so if you see this submitted under update status, my bad. Anyhow this is a new shock for a 96 Yamaha Kodiak 400 4x4 it fits my 96 Yamaha Timberwolf 250 4x4 perfectly. Little narrower are the bottom than the original but everything else is perfect. I extended it to almost a half in from full extension because I’m pushing 350 pounds. It rides and hold me well. So if any of y'allRace driven shock. have been looking for one and didn’t want to do the research here it is.
By Jim Denton
File limits have dropped for me. Down to 85 KB. I can only get my pics down to around 1.5MB. Have the limits changed because I'm a free member? This is on posts. I made an album in the pics section and wasn't throttled so hard. Just wondering.
Thanks, Jim
By Johnnyhorsepower
I finally found an awsome app for your phone that shows you on a map all the trails near your location. You can read or add reviews, look at picts...etc
Its called: atv escape
John
