By luckyyyyesther
Hey all!
By Sofaspud
By Am2007
Hi everyone,
owner manual
service manual
engine manual
By p5200
By opnea
Recently picked up a 1991 Lt230e for repair. Compression is a little low Id say, around 80psi, I also have spark but the spark is odd . When cranking the spark is a constant arc. I’ve got it to sputter but never fully turn on. I believe the spark is my issue, being constant and not detonating at the right time. I’m not sure whether this issue is an electrical fault like some missing ground, a faulty cdi, or a timing issue. Any ideas where I should start?
Similar Tagged Forum Content
- 10 replies
- 4,186 views
- 2 replies
- 3,546 views
- 0 replies
- 3,492 views
- 0 replies
- 3,423 views
- 1 reply
- 4,098 views
