2006 Arctic Cat 500 axle problems
weedoogie
hey i figured it out its the upper bearing, the inner race spun inside the outer about 0.050 causing the ball bearings to expand not enough to sieze in the cup but enough to eliminate almost all clearance for movement. the a arm drops axle comes out. i went out today and had a great ride and then totaly bend one of my rear axles, good times and good rides.
  • 3 months later...
    • By semicolon
    • By NZrider
    • By bighoss
    • By N00bie
      From Arkansas. Just bought a 2012 Gator 850i RSX because I could not pass up the price. BUT it has an idle problem. So, to be honest, I joined just to get a service manual. I have a choice: 1)Buy a hard copy: ~$100; 2)Buy a CD ~$35.00; Get a direct download for free posting 10 times; or get a download for $29.00 (subscription). Haven't decided what to do yet.
    • By ethie
      Hi All
      not sure where to start
