2005 Yamaha yfz450 running lean, i think?
i own a 2005 yfz 450 and i think it's running lean. when i get 3/4 to wide open it misses or cuts out. i have a k and n filter, yosh exhaust sytem and is jetted with a moose racing jet kit. main jet is dj132, pilot jet is dpjm048 and needle is set on #4. the fuel aire mixture screw was 1 and a 1/2 turns out but now 2 turns. spark plug is white. what should i do now?
Put a bigger main jet it. What size jets did the kit come with(I'm not familiar with moose brand jets)? The 48p sounds like a normal size, but I'm not sure about main. I used a gytr jet kit that came with my pipe and use main jets between 165-170 and pilots 45 or 48. If you'r screw is out 3 or more turns, you need a bigger jet.
Did any of the Suggestions fix your problem.....Everyone was right on top of it.....
Your Main jet Controls 3/4 to WOT......
Also,,,,,,,Make sure that the Float is set right..... To high will make it run Rich....Too low will make it run lean....When you do plug Chops......Make sure you use a new Spark Plug, Clean Air Filter and New Gas....If you can figure out a way to mark the 4 Different Positions of your Throttle location when you are Tuning it will be easier to identify the problem area for jetting....
The air screw is most effective between idle through 1/8 throttle.
The pilot (slow) jet 1/8 through 1/4 throttle.
The slide 1/8 through 1/2 throttle
The jet needle 1/4 through 3/4 throttle.
The main jet 3/4 through wide-open throttle
i had a friend of mine re-jet the carb. but yes, it is running alot better. done a few more things to it since but still haven't gone into the motor except to degree the exhaust cam back a bit.
Glad to hear you solved your by re-jetting the carb. Did you install a larger main jet?
    • By BruceG
    • By kantrud97
      Thank you in advance
    • By DarkRider
    • By p5200
      Hello, what is the best method for installing bearings into their race? I've set one in place and tapped it down until it was metal on metal. Is that sufficient? Surely it's not supposed to go into the race until flush? Also. does the coil spring on the seal go into carrier bearing housing not facing out? Thanks! 🙂 Seal goes in until flush correct?
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
