Here are some pics we took on our ride on saturday. The first few are posted in chronological order of my attempt at climbing a small hill made of logs, it was quite slippery. I tried twice with the same result and as you can see, I did not make it. Also, kids, don't be like my friend Brandon who thinks that because his Rancher is not fast, he doesn't need a helmet, he does wear one when he rides his 450R though.
It is always a good time, I live right by these trails, I don't even have to load up, I just ride right out of my driveway.
You Sir suck.:poke:
Thanks Scott. Yes MWKE, that is a 200X, good eye, and if you even have mud in Cali, you can send it here if you don't want it, I can always use a little more. We are a lucky few who have that option aren't we Wheeler.
    • By Frank Angerano
    • By Heymax
      I bought a 2003 Bombardier Quest XT 650
    • By That229Yamaha
      Hey guys, I’m new to the forum. What I got is a 2001 Yamaha Bear Tracker 250, got it as a project on trade and the problem I’m dealing with is a “no spark” problem and been trying to hunt down the cause for two weeks. I’ve replaced the stator, pick up coil, CDI, wiring harness, ignition, coil pack, spark plug, solenoid, battery, etc. and I’m still not getting any luck. Even tried bypassing the kill switch. I also noticed two things on this quad, another CDI under the back plastic by the voltage regulator, and a blue and green wire coming from the motor behind  the foot shift, tried to hook it up but it broke off and I’m thinking the broken wire would cause it to have no spark, if not then I need someone’s help on this and wanna see if I can get spark again. If anyone knows why I have this problem, the help would be greatly appreciated.
    • By afa913
      Do the small 50cc's have a way to set the speed. Im wanting to get one for my kid and i need to set it to go slow. I know the chinese knock off fourwheelers do but i dont really want one of those
