Have you solved your problem?
I edited your thread title because it did not include the year, make, and model, or a desfriptive issue. Maybe people will find it now and respond. :wink:
:biggrin:Well riders---I found out why my front end would not engage... You are not going to believe this but the rubber boot that covers the front of the drive shaft was torn and let the shaft silde back about 3/8". Now who would have thought that this boot is what holds the shaft into the front end. AC did not have a clue what was wrong. I found out my just messing around trying to figure out this Prolblem. Any body else haveing this prolblem check and make sure the boot is not torn. Chuck:cute:
    • By jimbo69
      my outlander 800 sometmes starts and does good ouker times starts but will not idle .any one else have same problem?
    • By tepin
      How come i cant download manuals i was told this is a good spot to find one for my lt230s quadsport.
    • By Shorty51
    • By TomJulio
