I just got my 00 400ex and I want to change the oil in it just to be on the safe side.. I found that there is 2 drain plugs one on the motor and one on the oil tank... But I can't figure out how to refill them? Is there 2 fill holes?
To change the oil:
Losen the 10 mm bolt on the right side of the crankcase. (oil should flow from that hole)
Add oil to the engine through the dipstick/oil filler hole as needed.
* Changed your thread title to better describe this topic.
theres only one drain at the bottom of motor and only filler located at the top of the tank fill slowly it holds ruffly a quart and 3/4.
    • By Trent Finnessey
    • By Mhatayas
    • By Dumass
