Polaris Magnum 425 idles fine, runs terrible
By kevinohio
By BillR94
By BillR94
Thank you for your time
Bill
By middlebrookgt
By C2INS
Does anyone know if they're interchangeable? I have a 2002 TRX20TE and 2007 TRX250TE, so getting to a set of common engine parts would be ideal.
