No start issue on my 2006 Ozark 250cc
Frankie
Hello i recently purchased a 2006 Ozark 250cc. Im trying to get it started but i get nothing. It does start and has fuel along with spark. I noticed there is a idle dial on the bottom of my carb. how should that be set. I think it is fully open as far as the dial goes. If someone could lead me to the process on how to tune the carb i would appreciate it. Thanks
well if someone did wind in the idle screw under the carbi, the bike would be harder to start, but most likely would still start up and rev its head off!
to play it safe wind the screw out 5 or 10 turns from where it is (assuming that it is wound all the way in) and try setting it once the bike is running (it can only be set once the bike is running and ideling all by its self)
has the bike been stored with out starting for a long time?
what was the bike like the last time it was running?
these little bikes are just so great and start very well. so there must be somthing going on.
are you using the choke (the little black lever of the left handlebar)?
Thanks for the reply. Now when i get it to start a lot of smoke burn through the exhaust as if it's burning gas. I get the impression that it is running too rich. I managed to get to idle but when i give it gas it chokes out and like if there is too much fuel running through the carbs. Do you think it may be a jetting issue?
i dont think it is a jetting problem.
because what you are describing is very bad!
and it would have to be a person changing the jetting, finding it was then running like a dog and blowing smoke and them leaving the bike that way.
initialy I would ask if your airbox if full of fuel?
or is the vacume line on the fuel tap is wet (it is the smaller hose, and should be completely dry inside)
or there is the possobility that the fuel is contaminated with diesile fuel, not petrol.
Well when i first bought it it had fuel in the airbox even in the crankcase. So i had to do two oil changes to clear the fuel out. I had filled it up with fresh gas since most of the gas when i bought it was in the crankcase. I checked if the fuel tap was working and it is. When i disconnect it no fuel drips out only when i go and start it so that's out the question. Where are the pilot screws on thing. I don't know much about this carb. I have a yamaha banshee and know my way around that carb very well and i can tune it like nothing. I come upon across this here and i am stumped. Any type of feedback i can get i would appreciate it.
your fuel tap auto shut off can still be working, but what I am talking about is the VACUME line going to the back of the fuel tap.
it is where some vacume is constantly sucking the back of the fuel tap, to open the 1 way valve to get the fuel flow out the OUTLET of the fuel tap.
there is a problem that can happen to the fuel tap where the thin rubber bladder that the vacume pulls against, the thin rubber can be damaged and it can flow straight fuel right through the rubber (which is not ment to do it at all) and the fuel will travel down the vacume line and it enters the inlet track in to the motor and the bike can be iether rich... or even completely flood the motor.
this is why I was asking if the vacume line was dry inside, because if there is even a little wetness, then the rubber bladder is letting fuel through. (which is a cause of the bike running rich)
I took the carb completely apart and noticed that the small diaphragm rubber gasket was not sealing properly. I noticed the black rubber gasket on the diaphragm was pinched wit the one of the screws and was not set in they way it suppose to. Could this issue be my problem of why this thing sounded so rich and flooded my crankcase? Im going to give a shot tomorrow when i get off of work and let you all know if this cured the issue.
Im also going to inspect the fuel tap. as well thats some really good advise and never would of thought of that. Thank
Alright i have an update on my progress on this Suzuki. Well as Profill has said to check the diaphragm on my fuel tap. Well what do ya know, the diaphragm on my fuel tap was corroded letting fuel into the carb through the vacumm line. I switched fuel tap with my KFX 400 since they are the same and the Ozark ran really well, just a few adjustments but ran excellent. Thank you. Tomorrow to the bike shop i go in hopes they have one in stock. Your very knowledgeable thanks!
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By Spritee1
      not sure where to look next
    • By justent_88
    • By semicolon
