Got a 2005 Arctic Cat 500, Its automatic, and 4x4. I have stock 25" tires right now but i am looking to go to at least a 26" but maybe a 27". been checking out tires and reviews and like the maxxis mud buggs, what do you guys think? I know on 650's you have to upgrade the belt, do i require this mod also? Other than mud bugs what are good tires for mud/ trails at a descent price?
u wont have to upgrade the belt as long as u keep the tires under a certain size...um u can get mudlites, gbc dirt devils, gbc grim reapers, zillas, there are many light weight a fairly cheap tires out there
Grim Reapers are a heavy tire like the Maxxis BigHorns. From what I have heard the Reapers give all round traction like no other tire. They are also 8 ply tires.
oo thanks for clearling that up BB....8ply tires wow that is one thick tire
Edited by outlander560
I just installed a new set of Maxxis Bighorns 2.0 on my machine. I heard nothing but good things about this tire. Can't wait to try them out.
Mike
Can you please give us a ride report on them.
  • 5 months later...
    • By mehim
    • By logray
    • By tepin
    • By Shorty51
