I assume you are talking about the pilot screw, the best way to set it is to start the machine and let it warm up, then slowly turn the screw inward until the motor starts to stumble, then start turning the screw back out until you reach the highest idle point, when the idle starts to go back down, you have gone too far. Set it at the point where the idle is highest and, if needed, adjust the idle to an appropriate setting.
    • By colin james
      View File 2017-2019 sportsman 450/570 with eps factory service manual
      This  is the factory service manual for the 2017-2019 factory service manual for the sportsman 450/570 with electronic power steering
      Submitter colin james Submitted 09/06/2018 Category Polaris ATV
    • By Louznmemind
    • By nduray3
      Is there anyway to make the pilot screw accessible on a 1996 Suzuki king quad
    • By killerklown
      What's the proper diameter recoil rope to order for a Bayou 220? I didn't see anything in the manual.
    • By drobbie98
      Hey all, Thanks for having me in the forum. I just purchased my first ATV and am stoked to understand more about it.
      The first stupid question will be, what is everyone's maintenance schedule? DO yo follow the recommended intervals or build one yourself based on the machine.
      Thanks in advance.
