dON'T KNOW IF IT IS RELAY OR SOLENOID. It might be an addition for my winch?? It has 4 bolts, the battery is wired to it and the winch. Cannot find it in any schematics. It is located in the back body above the muffler.
they do not run separate solenoids on quads for starters all they use is a relay to send signal to the one that is mounted on the starter itself. they come as a unit. if it is a separate soleniod then it is most likely to be for an aftermarket system probably a winch.
your friendly neighbourhood mechanic.
    • By TomJulio
    • By HeWasRidinDirty
      The one I need to replace has a 2 wire plug coming out of it. Searching eBay I see tons of them with only 1 wire . WTH???
    • By gordonmacritchie
      all fuses are fine
    • By quadnut20
      Looking at replacing tires on my 2003 Foreman and was seeing what everyone is recommending fore it ?? Its mostly a plow machine but in the summer the  kids take it out !!
