2005 Polaris Sportsman 500 Fan Replacement
By BruceG
By BenJammin
By Roofus
I cant seem to find what this part is called. Can anyone point me in the right direction? I must be misinterpereting the parts catalog or something? I dont see it in the rear axle section. I think it may be in the rear brake assembly section? click link to view picture.
[removed broken image]
By Clydaho
Any other ideas?
Thanks for any help,
Clyde
By Its-always-something
