2005 Polaris Sportsman 500 Fan Replacement
By Roofus
I cant seem to find what this part is called. Can anyone point me in the right direction? I must be misinterpereting the parts catalog or something? I dont see it in the rear axle section. I think it may be in the rear brake assembly section? click link to view picture.
[removed broken image]
By BruceG
By BenJammin
I did a compression test on my 2005 Bombardier Traxter 650 CVT and it's 75 PSI. service manual only talks about leak down test. No specification for engine compression the manual. What does 75 PSI tell me? Thank in advance.
A little history of this machine. 640 miles. Picked it up about 2 years ago, not running. Probably the computer. Tested all circuits and confirm it was the computer. Long story short, I watched a Youtube video and fixed the computer. ATV now started and runs. BUT, it tops out 20 MPH. I cleaned the carb 3 times also using a Mikuni carb kit after the second time. Slide in carb is going up and down. Only adjustment for fuel is at 1.5 turns out. NGK Sparkplug had soot on main part but brown on the electrode. Champion sparkplug is brown. I check CVT clutches and they both appear to engage like they suppose to. Checked valve clearance it's 0.00, I can't get any feeler gauges in-between. I check timing chain I believe it's in the correct position and hasn't skipped. I removed muffler plug and drilled into muffler to try and make sure it wasn't plugged.
By Clydaho
2022 Sector 550, 414 miles on it and the gas gauge reads empty. I topped off the gas and it didn't change.
There is no fuse that I could find. No access at the gauge cluster.
Has anybody removed the tank lid? Any tricks?
Any other ideas?
Thanks for any help,
Clyde
By Its-always-something
