hi everyone im new to the forum,
i got a chinese quad 4 months ago and before you start saying thats what you get for not getting a branded quad i got it for €100.
my quad occasionally back fires when i take off and if i leave it to idel it eventually sputters and dies..
any help is much appreciated.
p.s. i have the ability to work with it mechanically but i dont have any special tools :biggrin:
The easiest way is to pull the plugs. Black = rich / white = lean and a light tan = just right.
A black dry fluffy colored plug is caused by deposits from a carburetor that is running too rich (too much gas), or excessive idling on some engines. Black smoke coming from the exhaust is a sign of a rich air/fuel mixture. The rich air/fuel mixture must be repaired before installing a new spark plug. Common causes for a rich air/fuel mixture are:
dirty air filter.
air mixture screw or carburetor needs adjusting.
choke is sticking.
carburetor float height is out of adjustment or float is sticking open.
Yeah, try to keep water away from a foam air cleaner. If you own an air compresor, just blow some air on it to try and clean some of the gunk off of it. but yeah, i've used water on an air filter before and that was a hugeee mistake
i was playin around with the carb adjusting that half washer on the needle changing the position of it and then checking the spark plug but every time the spark plug was black even on the leanest setting. on the middle notch it was ideling ok but now on the leanest notch she is dieing after ideling for a bit even tho the spark plug is turned black.
im confused!!! :aargh:
Yeah I try not to play around with my carb. I did that once and had to order a whole new one. Just try to adjust the choke? That could be your problem, I know the choke on my quads sticks sometimes.
if you r running rich it will actually make your plug foul and wet. the perfect colour of a plug is a dark tan colour. if it idles and shuts off and also backfires when you give it gas it is running to lean. a rich mixture will not cause a backfire. it will ccause it to bog. turn then air fuel mixture screw all of the way in gently then turn it out approx 3/4's to a full turn. then start the quad. leave it in nutral and rev then throttle the engine up and down while fine tuning the mixture. adjust it until the bog is gone then turn it back an 1/16th of a turn. that should be set pretty accurate. if you have any other questions feel free to drop all of us another line.
your friendly neighbourhood mechanic.
i have no idea what brand it is unfortunately and i think it DID have a adjusting screw and was very very poorly done, when i was riding it fell out so there was a hole where it used to be and i had to fill it with gasket sealant... it fixed the problem. i cleaned the spark plug and ran it and it was black and it was still back firing when decelerating... :confused:
Adjusting the air/fuel mix at idle is done with the pilot screw, it is usually found on the bottom of the carb just forward of the float bowl. You can get stuff for cleaning your filter at a dealer, just spray it on, let it soak, and rinse it off. Yes it is perfectly ok to use water on your filter, just make sure you let it sit and dry naturally for a day or so, or until it is completely dry. Some people use diesel fuel to clean foam filters.
You have to check the carb in three diffrent positions. The needle controls about 1/4 to 1/2. The pilot jet and starter jet control up to 1/4 and the main controls 1/2+ To check the pilot check a new clean plug but accelerating only to about 1/4 throttle. The you need a new plug to check the main. Talke it up to full throttle then put it in neutal and coast to a stop while cutting the engine. This keeps the needle and pilot from fouling the plug. I suck at jetting but once you have enough experience it is almost second nature.
What is your temp and elevation?
    • By Thekevinjb
      thanks
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By Rich1028
      I Crashed My Quad
      Below are Three Videos.
      5 broken Ribs
      1 Punctured Lung
      1 Broken Collar Bone
