Similar Topics
By rgeiser
just wondering if i pay the thirty dollars how soon will i be able to access the manuals?
By geezer99
Well, I bought the Axis 500 sold at Lowes for $8999 a couple days ago. This post will be about my impressions as I use, fix, and abuse the machine. I will add to the post as I gain experience with it.
Thanks to other posters on this site warning of new machines with loose hardware, one of my first actions was to crawl all over it checking fluids and connections. Zirks were all freshly greased, fluids in engine, and gear boxes were up to level. One of the little gas struts that help lift the bed to dump was dangling with only one end connected, and the other strut had not been fully tightened.
The rear gearbox does not have a differential in it. It is essentially a solid axle. Tight turns on lawn will leave tracks, and turns are not as tight on pavement. In my case this won't matter much, but if you plan to use it on a lawn, this will create tracks on turns.
To check engine oil you need to remove both front seats and a plastic cover. This according to the manual. I'm pretty sure it can be checked with that stuff in place, either from under or above, but that remains to be seen.
I am not used to a CVT transmission. I am used to a clutch and multiple gears. This one requires giving it plenty of gas out of the hole and then backing off to get it to shift up. I'm sure I will get used to it, but I'd like to be able to take off quietly if I want to.
The doors have bungie cords to act as springs to close them. I removed the driver door so I would not need to fight the constant pressure to close. Problem solved. I will leave the passenger door as is. Gotta keep the grandkids safe.
Here is some stuff I like:
I was concerned about there being enough torque to slowly climb a steep hill. There is. I will elaborate more on this when I've had it on my steeper trails.
The display has dedicated lights to indicate status of gear position, low oil pressure, over temp, and a bunch of other stuff. This helps a beginner with feedback that an action taken was successful.
The sparsity of knobs on the tires dig in well on most surfaces. I bet they wear out fast on pavement.
The tilt bed has a tail gate that is easy to operate. Much like early Japan pickups.
Steering is responsive and little slack. Remains to be seen how long to get loose since the u-joints are operating at quite sharp angles.
Seats are pretty nice. Will be interesting to see how long it will take me to poke a screw driver though them.
Seat belts are included to hold grand kids in. Won't go over 5 mph if both aren't buckled. Yeah, it works to buckle them empty. Doing this leaves the belt high on back, so you don't have to sit on it.
Hauling it home, my trailer wheel wells were too close together to clear the tires of the UTV. This required driving it off center a bit, with one set of tires inside the wells and one side driving over the wheel well. Creeping over the one well required climbing a 10 inch vertical well. The ability to lock the front axle differential kept both front wheels pulling as I drove the one side up and over the wheel well. The guys at Lowes were impressed. They won't touch any but an unobstructed flat trailer loading.
tom
By Thegrizz
So, I just bought this quad off a acquaintance of mine… anyways, it’s missing the airbox which I’m trying to purchase if I could only figure out the year and what model of lt230 it is due to having only 9 visible digits for a vin…guy said he had the title at one point and lost it when he moved houses after the flood of 08 in Iowa….I just desperately need to know what model this thing is so I can start getting to work on it….it does run after a good carb cleaning….I’m having trouble getting it to idle though due to essentially just having a rigged up air filter with no airbox on the bike…I’ve sanded down the plastics and it looks like the original color was orange and the seat I believe is either from a different Suzuki or it’s been painted gold and black? The plastic nose part is originally black…it has the lever for reverse by the sprocket it has a pull string to start and I think originally it has electric start as well….idk I’ve had to bypass and use a screwdriver on the starter Solenoid to get it to start …someone has definitely done some rigging with the wiring as well.but if anyone has any clue what I need to look for to identify the year and actual model so I can get the right stuff. I’d appreciate it.
By kodiakbigbear4004x4
BEEN LOOKING AT LOWES AT THE NEW HISUN AXIS RHINO CLONES ANY ONE EXPEINCE THEM ARE THEY ANY GOOD OR IS THE MASSIMO BETTER LOOKIGN FOR AFFORDABLE UTV
Similar Tagged Content
- 4 replies
- 2,305 views
- 3 replies
- 2,294 views
- 1 reply
- 1,313 views
- 0 replies
- 1,342 views
- 2 replies
- 1,771 views
Gallery Images
