By rjsummer
By Asand211
By TravisCr
I appreciate any suggestions- normally I'm a jeep and honda dirt bike guy- but I got a good deal on the quad and a plow so I went for it
By geezer99
I have an Axis 500 made by Hisun. I uses a solid rear gearbox with no differential action.
I would like to convert this to a true differential with locking ability. I've searched all over trying to find a source with no luck.
Has anyone done this before, or know of a source?
Thanks, Tom
By robert63
my cat only has 100miles on it and is in mint cond. since i bought it new in 2009 it has had what i believe to b a carb problem. going down a steep hill makes it want to stall. as soon as u r on level ground its fine.and at top speed it kinda acts like its starving for gas. u let off the throtel a bit n its fine. idels good starts good. hav taken it back to dealer several times. they eithor said it didnt do it or mayb bad gas. my friend says it sounds like the float level isnt rite. any advise would realy help.
