For my engine overhaul I need a service manual:
2003 Yamaha Bear Tracker YFM 250XR Modelltypcode 4XEK, Ident-No. 5Y4AG01W030509601
Thank you very much!
Hi there, I am looking for a service manual for 2004 350 Bruin. YFM35FAS. I have a charging issue, trying to find specs on ohm readings from stator. :mad:
Thanks muchly!
this is the only 350 manual i have from '04 ... hope it can help
Edited by oxidized_black
Hi Ox noob on here
Question & request - buddy has a 1995 Big Bear 350 2 x 4 chassis num # 4UH 017286 1995 # I have the YFM 4 x 4 manual & wondered if they did one for the 2 wheel drive as it runs like a cripple dog, tried carb settings for 4 x 4 but no joy.
TIA
Fishy09
Hi Ox noob on here
TIA
Fishy09
all i have is the 4x4 on page 1 of this thread, post #3. i know the carbs are a real pain to get right, i had to do mine about 8 or 9 times before it was right. not sure if the specs would differ that much ...
Ox
Appreciate your reply, that was my thoughts also but may need to try messing with needle height & Pilot jat a bit more, unfortunately I am not the firsy person to look at the machine so will have to strip carb myself & check all gaskets & diaphram etc yhen take it from there, forgot to mention this is a Euro model also so could be different specs due to temps & altitude here etc.
One other point would the carb being out of adjustment cause occassional backfiring when trying to rev engine or is it possibly Ignition related ?
Grateful for all comments though
Cheers....... Fishy
    • By hengstserepair
      Nuetral: Runs as expected
      Lorne
    • By Mister907
    • By jeffinotown
      QUADCRAZY NEEDS YOU!
