swampcat07
Quad Crazy Member Ride PA, NY, & NJ
Ok, we are all agreeing on Tall Pines? End of September would be better for me. I have 2 birthdays( weekends) and my anniversay in the middle of October. Or even beginning November is ok.
Most likely it will be Me and I can prolly get Mark there too. Maybe also a 3rd rider but not sure.
Well I figured if I did not pick a place and time to at least talk about we would never get anywhere.
Tall Pines seems like the best fit for the location and insurance requirements. If we tend to be getting more members from one specific area we can always move the ride closer to them.
Any week in October would work for me. What weekend do you have free in October?
Share this post
Link to post
Wait what about SSRT??
Wylde does not have insurance on his quad so I don't think SSRT would give him a sticker.
I am just trying to see what place works best for everyone.
I am planning a trip to SSRT sometime this fall, You just have to watch what is in season to hunt. The off trail riding is fun but you don't want to get any of the hunters mad.
Share this post
Link to post
I don't think anyone is really confirmed yet we are still back and forth about a place and what weekend in October. If we can throw a few options out there I will start a poll.
Share this post
Link to post
only reason I am asking is if the ones that are confirmed to go have reg/ins then SSRT I think is the place to go. Guess the one w/o reg/ins are the one that really need to commit since the location of the trip is around them.
Maybe shoot out some dates and if they have reg/ins and start from there. If you need any help let me know, Mark
Share this post
Link to post
If you guys get enough people for a certain location go for it. You don't all need to try to work around me. It seems I am the only one that doesn't have the paperwork. I am in the process of changing jobs right now anyway and would really be stretching my budget to do it.
Share this post
Link to post
SSRT is on top of the poll. With that said what weekend in October is everyone thinking about?
1 - First Weekend 5th thru 7th
2 - Second Weekend 12th thru 14th
3 - Third Weekend 19th thru 21st
4 - Fourth Weekend 26th thru 28th.
The official Ride will be that Sunday for those who are coming down for the Day.
I would not be able to make the Ride on the 21st so I vote for the First Weekend.
Week Voting and Attendance.
______________________________________________
1 - Swampcat, Marioweldinginc, Markdb, Lumpneck
4 - Swampcat, Marioweldinginc, Lumpneck
Edited by swampcat07
Share this post
Link to post
Good Point Mike. So the last week is also an option. I will start a count who can make it the 1st week and then who can make it the last week. Let me know if you can make it and I will add you to the list.
Share this post
Link to post
  • Similar Tagged Content
  • Similar Topics
    • By VikingTrad3r
      picked up my third timberwolf 250 for my daughters.  these are great light weight little quads.
      have a strange one for you.  the quad will NOT start in neutral.  it will start in first.
      if i lift up on the gear selector just enough to hear the little click (its not loud, sounds like a contact clicking, perhaps the neutral safety switch?) the light will go out, but it won't yet be in first either.  that is how i have shown my daughter to start it and she can.
      id like to carry out whatever repair is needed.  i have the pdf of the shop manual but it doesn't really have a flow through diagram.
      any help appreciated!  thank you.
      i need to add something.  it feels like i can switch into another gear BELOW neutral.
      so if i switch to neutral, i can keep pushing the gear selector, and it has another click below the neutral.  the light stays on, and when i pull up into first it kind of feels like it has two positions it moves through to arrive at first.
    • By billyz57
      New to Quadcrazy, Has any Yamaha owners had similar issue?
      1987 Yamaha YFM 350 Starts on Pull, but just spins on starter, and won't start.
    • By bradleyheathhays
      '96 Cherokee here and right now I'm dealing with a no start after a few weeks of suspicious symptoms. She's been driven a lot less over the past year and about a month ago she began starting a little slow. I've got an oversized battery in there so usually she cranks right up no problem. I started monitoring batt voltage and saw around 12.04 V with engine off and 14.10 V or so running. Right before I get the new battery I head to Advance and they run a battery/alternator test. Kid tells me my batt is bad but alternator is still good.
      So I lay out the $ and install the same size 34N EverStart Maxx 800 cca from Wally's and the slow start persists. Measuring the new battery with engine off yields consistent readings of just under 12.7 V, so for the past few weeks I began charging the batt at 2A which seemed to help. A few days ago I venture out for an errand and the engine doesn't restart to get me back home. I get no clicks or cranking at all with a key turn. Batt measures 12.67 V at the terminals. Dash gauges seem to react with the key on, voltmeter reading ~11.5 V, although I'm not sure how accurate that is. Fuel pump pressurizes.
      Something that happened right after battery change out, which may or may not help in diagnosing the problem, is that my pass side headlight only illuminated half way while the driver side stayed full bright. I have an LMC Truck aftermarket headlight wiring harness giving 55/100w low high beam. It's the kind where you run the lights straight off the battery through additional relays. Had to tinker with the light harness a bit to get the new batt in and may have compromised a connection? Maybe a ground? Either way the pass headlight started showing full bright after only 1 or 2 occurrences and has been right ever since. With my alternator testing good and a new battery I wondered if maybe a loose connection was draining my voltage. I was in the middle of testing batt V connected vs. disconnected over time but this no start happened before I could get it done.
      Last thing to mention is that recently I've been removing both my fuel pump and starter relays for security reasons. The way it's acting now is exactly like when trying to start with both relays removed. Being that the fuel pump is pressurizing should I consider testing the starter relay? Other than that could I have caused some kind of part failure by removing and reinstalling the relays maybe around 5-6 times over the last month?
      All ears
    • By Belmontie
      Hi all, bike does start with the electric start mostly, but the battery was weak and wouldnt start it the other day so went to use the pull start, to say its hard is an understatement first of all you gotta do a little jiggling about til it catches then pulling it takes some effort now i know im not the strongest fella in the world but this is so much harder than it should be.
      It does start of the pull just to get the engine to initailly turn is so hard any ideas why its happening or how to fix this,
