Similar Tagged Content
By Kyboy
Iam looking for help seperating the rear brake drum and the cover. Any suggestions would be greatly appreciate
By crazynordlander
Hi All,
I live in Minnesota and bought a 2016 CFORCE 500 HO. I am in hope to see if there is anyone in the US that is experiencing this sudden drop off in RPM below 4000 RPM. I have uploaded some videos of my issue on YouTube. I will list three of the four I posted. The fourth can be found on my channel but it is a comparison between my Polaris 570 and my CFORCE 500.
I quit on my first dealer because we just did not mix well together. I brought it to another CFMOTO dealer that just became a CFMOTO dealer in January 2016. They are in a large ranch and agriculture area in a neighboring state that is pretty close to where I live. They have close to every brand available. They are a much larger dealer than the first one I bought the unit from.
I brought the unit three weeks ago to them and they have worked on it a good solid week and have given up on it. I have read reports from owners in Canada that the dealers there were aware of the issue and have had success in fixing the herky jerky drivability issue.
I am picking it up tomorrow and bringing it back home. It has been to the trails of the Black Hills this year and was new in late April. 300 miles on it. It has never changed. Very hard to ride on the trails or when I herd livestock.
Here are the links to my videos.
I can't accept that this is normal operation. Does anyone from CFMOTO China scan these posts?
I need help that CFMOTO USA has not provided.
Kevin
By ut1w7b
I have a 94 sportsman 400. It sat for several years before i got it. I have cleaned the carb it will start and run for about 5 min then it will flood. I have torn it down and cant see anything wrong. has anyone else ran into this problem any hel would be great.
Similar Topics
By NathanFisk
I have an 2003 Kodiak 400 Automatic and for some reason the starter not engaging I’ve replaced it still nothing it spins freely but not engaging. It was running fine the day before I am no expert so can someone please help me
By AKMichael
Hello All,
I have a 1999 Yamaha Big Bear 350 4x4 trying to get fixed up so my grandson can go out in the woods with me.
We have owned it over 10 years. It got harder to start, until it finally would not. Replaced the carb. Right afterwards, it started and ran nicely, but after turning it off, would not restart. Tonight I used starting fluid and ran, then died. Adjusted the idle up a little, used more starting fluid and ran great. It idled about 15 minutes. Turned it off, and restarted. Ran it around the yard about 5 minutes. Turned it off, and would not restart.
Any ideas or suggestions would be greatly appreciated!
Thank you.
By NoahJakavi
Hello i have a linhai 300 of the 2004+- era. I had a cluch problem so we changed it. After changing it has a hard time to start going. When you pop it into gear and press the gas it barely drives but when it starts going about 20km/h it start driving well the acceleration is normal and everything do you have any idea of what could be the problem
By VikingTrad3r
picked up my third timberwolf 250 for my daughters. these are great light weight little quads.
have a strange one for you. the quad will NOT start in neutral. it will start in first.
if i lift up on the gear selector just enough to hear the little click (its not loud, sounds like a contact clicking, perhaps the neutral safety switch?) the light will go out, but it won't yet be in first either. that is how i have shown my daughter to start it and she can.
id like to carry out whatever repair is needed. i have the pdf of the shop manual but it doesn't really have a flow through diagram.
any help appreciated! thank you.
i need to add something. it feels like i can switch into another gear BELOW neutral.
so if i switch to neutral, i can keep pushing the gear selector, and it has another click below the neutral. the light stays on, and when i pull up into first it kind of feels like it has two positions it moves through to arrive at first.
By texaskaw
fighting this thing for a month now.No spark at plug.
New ignition coil,pick up coil,stator,reg/rectifier,all new wiring.Started it up today rode for an hour shut it off.Tried to start later wont start.pulled plug wire it firing a blue spark while starter button is pressed.Tried new plug no change. It stared a couple times an ran for few seconds then died.Will CDI act this way? The reg/rectifier get pretty hot is this normal?
