2008 Raptor 250
Key Features:
Lightest production sport ATV ever—for amazingly nimble handling and a great power-to-weight ratio.
Aggressive Raptor style and stance for maximum performance and excellent, all-day sport-riding ergonomics.
Class-exclusive five-speed manual transmission has a gear for almost any terrain.
Torquey, durable air-cooled engine puts out plenty of power and starts with the push of a button.
Low-profile 19-inch rear tires for outstanding traction and handling.
Longest suspension travel and lowest seat in its class for true sport handling.
Engine:
Light and powerful 249cc air-cooled SOHC four-stroke single produces a broad, deep powerband.
Five-speed gearbox with manual clutch provides the flexibility to tackle pretty much any track or trail.
29mm Mikuni carburetor provides light throttle pull and excellent throttle response across the entire rpm range.
Electric starting is standard equipment and works in any gear.
DC-CDI ignition system delivers consistent spark at all rpm levels—for quick throttle response and a smooth, broad powerband.
Ceramic composite cylinder liner for greatly reduced wear and excellent heat dissipation.
Oil cooler keeps engine temps down and lubrication up in hot conditions.
New-design airbox features no-tools air filter access.
New-design three-chamber muffler is light, quiet and boosts low and midrange performance.
Chassis/Suspension:
Light, strong, short-wheelbase chassis creates a quick, super-responsive high-performance package.
Low, 28.7-inch seat height enhances rider comfort and allows optimal rider movement.
Independent double-wishbone front suspension with five-way preload-adjustable shocks gives 7.5 inches of wheel travel.
Lightweight aluminum wheels reduce unsprung weight for excellent suspension performance, acceleration, deceleration and handling.
Triple hydraulic disc brakes deliver excellent stopping power even in wet conditions.
Extra-wide, YFZ450-style footpegs provide excellent grip and rider comfort.
Easy-to-use, flip-type handlebar-mounted parking brake can be set with one hand.
Rigid and light swingarm rear end is controlled by a shock with adjustable preload and 7.9 inches of wheel travel, for consistent wheel control and rider comfort.
New-design Dunlop tires deliver outstanding traction for razor-sharp handling in a variety of terrain.
Easy-adjust eccentric chain adjustment feature means hassle-free chain maintenance.
Flat, composite skid plates provide maximum underbelly protection.
Rugged steel grab bars front and rear help fend off debris and damage.
Additional Features:
Dual 30-watt multi-reflector Krypton headlights straight off the potent YFZ450 add the perfect menacing appearance. Taillight has an incorporated brake light for added convenience.
Waterproof electrical connectors for outstanding durability and reliability.
Easy-access grease fittings on all chassis lubrication points simplify maintenance and help extend the life of the Raptor 250.
New-design bodywork comes off without the need to disassemble electrical parts, airbox or wiring harness—for easy maintenance.
2.4-gallon fuel tank means less filling up and longer, more enjoyable rides.
2008 Yamaha Raptor 250 Home, information, info
The raptor 250 is the fastest 250 out there me and my brother have tested it against other 250's and none of them even come close in a race or riding on the trails we put the 250 raptor up against a 300ex with exhaust and a K&N filter and the 250 raptor stayed right next to it, so yamaha is doin something right
    • By Jdeaton011989
    • By GTX-Racer
      I am looking for a PDF version of a manual for a Suzuki Quadrunner 250.  I am not sure of the year, but believe it is a late 1990s model.
    • By wilmpie
      hi everybody
      I have a kymco mxu 250 automatic from 2006 250 cc  that keeps going forwards or backwards when i shift backwards or forwards an then shift to neutral .
      if i shutdown the motor and push the quad and restart then its in neutral and don't go forwards or backwards, i already checkt if my motor is running good stationairy .
      what can it be or what can i do to fix this?
      thanx in advance
      p.s. Sorry for my bad english it's not my first language.
    • By DarkRider
      Hey Everybody,
      Some of the features I tend to like best  (aside from durability and reliability)
      Durability is how long I can go without something breaking. OR how often things break with seeming not much of a good reason. Reliability is about the on-trail experience of having everything work properly as designed (i.e. Starting up and being able to get going without much issue, the 4wd drive engages without quirks, I can park it on a hill when needing to help someone else without worrying it'll roll away, etc) My Brute Force 750 is a perfect example of why Durability and Reliability were rated so differently. With durability, I really never felt like I've had anything break on the thing that was really from riding it. Which is great in that regard. But all of the things i've had to fix on it seem more so in it's design. The infamous KEBC code on the dash that refused to go away even after completely cleaning and lubing the KEBC and confirming it functions properly. Hard starting issues. 4WD requires you to roll about 10 to 15 feet to engage, so if you get stuck in 2WD, you're in a pickle. The infamous bus connector that goes bad and stops your charging system from working. I've worked through all of these, but these are all things I'd consider reliability issues that happen really at no fault of mine as I ride it pretty gently. Writing up this list has actually put a lot into perspective for me. The King Quad 300 really is a superb quad. The inclusion of the Super Low range provides stellar engine braking down pretty much any hill you can think of, it seems like it's unmatched. It has great gas mileage, and it's been dead reliable despite being a 1994. It's got 4x4 AND Diff lock, and the semi automatic transmission also help with not letting the quad get out of control down a hill. Plus it's more fun to me and gives me a bit more to do while riding. The biggest annoyance so far has been the parking brake. No matter how much I adjust it, it just doesn't seem stay adjusted after some time. I believe this might just be flawed on these models.  Also, parts availability is not the greatest on these since they don't make anything newer with any similar parts. Front axles are quite expensive, rear drive shafts go for $400 to $500 brand new, etc.
      And that's where the Park gear on Yamaha's Ultramatic eliminates that issue. That's where I keep landing on the older Grizzly or Kodiak 450s. They have a park gear, IRS and Diff lock, a lot of power and they're super fun to ride (got to test one).  But I'd be giving up fuel efficiency and the Super Low range. The Ultramatics still have good engine braking, but still not comparable to the Super Low on Suzuki.
      With ALL that said, curious about what other people out there have had and enjoyed, and I'm just looking to get some ideas of what other smaller/mid sized quads are out there with similar features.  I don't really know anything about Honda, Suzuki, or Arctic Cat models from the mid 2000's.
      Make Model Year Parking (gear/brake) Engine Braking Fuel Efficiency (mpg) IRS Diff Lock Durability (1-5) Reliability (1-5) Overall Rank (1-5) Suzuki King Quad 300 1994 Brake Super Low range 20 Yes Yes 4 4 4 Honda Rancher 350ES 2002 Brake (none?) 17.5 No No 5 5 4 Kawasaki Brute Force 750 2005 Brake KEBC Module 12.5 Yes Yes 4 2 3 Yamaha Grizzly 660 2006 Gear Ultramatic 12.5 Yes Yes 5 5 3 Yamaha Wolverine 450 2009 Gear Ultramatic 17.5 No No 4 5 3 Polaris Scrambler 4x4 4-Stroke 2002 Brake (none?) 14 No AWD 2 4 1 Polaris Sportsman 500 4x4 2000 Brake (none?) 15 Yes AWD 2 4 1
    • By Gtc4d
      Thanks.
      Todd
