Need some advice... The exhaust coming out of the engine glows red hot when running for a few minutes. I have been told it is running too lean. How do I fix this? is there an adjustment on the carb? if so, where is it located? Thanks!
If if an engine is running to lean the exhaust should not glow red hot! Sounds to me like something is restricting your exhaust for example: nest from dirt dobbers, rats, squirrels and other little critters can cause this. This same thing will occur on many vehicles with catalytic converter/s installed that become clogged over time. Hope This Helps, Whip
probably 3 bolts starting near the seat. one will be a clamp to the straight pipe and then the other bolts would be to hold it to the frame. i would just take the muffler off and run it to see if that makes a difference. i have heard of running a garden hose thru the muffler to rid mud mud etc. ...
ok great, I will try that. Stupid question tho... wouldn't you be able to tell if it is plugged simply by checking the end of the pipe while it is running (without taking anything off)? Or can it be restricted just a little, causing it to glow red hot???
my buddy had a 750 brute that was plugged and had the motor rebuilt from kawasaki and they didn't know, so, it's an easy check really, just a few curse words getting that bolt under the seat by the fender LOL
you'll get some pressure coming out, but maybe not all that it should be ... and if it still glows when the muffler is off, get a wire coat hanger and straighten it out and shove it down the straight pipe, but put a peice of tape on the hanger so you don't go too far in ... measure it a couple inches up from the bend into the cylinder
Sounds like ur running lean Bigger Jet will help !! If you got a spark arrester I dought anything is in ur exhaust unless it ate the screen !!
I would check first for air leaks or torn boots before the carb or airbox. Is the lid on your airbox?
Did you snorkel the quad or replace/modify the muffler?
Also how cold is it there. If it was running fine before lets start threre.
  • 9 years later...
Hi i have a problem with my 2001 arctic cat 300 4x4 before we heard the ATV was backfiring and we saw a hole in the air intake boot so we replaced it  but still backfiring we think its running rich but we cant figure out where the screw is to chage that can anyone help
    • By marlon smith
    • By digrig
      Hey everyone,
    • By BillR94
    • By WeeBee
    • By Ironworker709
      I have Grizzly 700 that has been pretty much totaled out in a bad accident, but it will still run and drive good...
      Will this engine swap into any of the Yamaha UTV's like thr rhino and Viking 700's?
      Was just going to sell it as is for a engine for someone who needs one pretty cheap..but been thinking about getting a UTV for the family and maybe find one with a blown engine cheap and swap it out
      I already an excellent shape 2001 Big Bear 400 4x4 for us..but kinda been looking for a good used UTV for us and the grandkids on our property to play with
      Not sure of the year..i can't remember what year it was when i picked it up for a buddy a few years ago..he went to jail after he totaled this thing and told me to pick up a few things at his house he was renting and just keep them for myself since he owed me a bunch of money before the landlord sent them to the dump...
      The first picture is when i went and picked it up for him..second is how it is now..frame is all twisted up and plastics are fubarred..going to sell the rims and tires.they stick out way too wide on my Big Bear
