Join Today, It's Simple and FREE!
Similar Topics
By Dra O
posted a while back - it was running at one point - I have all the plastic shroud off - it's down to frame and engine now
-fuel pump: when line from petcock is attached, no fuel comes out other side to carb; the line to the carb is open (can blow through it); I thought when I cranked engine that the pump would spit out fuel on other side but it does not; I removed fuel pump and opened it up - diaphragm looks good - but internal areas had lotsa calcification build up - I cleaned this out and dried it good - the clear plastic pieces (?diaphragms) aren't broken - the spring w/ steel ball on end moves freely; am putting it back on tomorrow; but can anyone answer about the pump? isn't it supposed to pump fuel through it... to other side... to carb? puzzling
-along with fuel pump: I replaced petcock 3 weeks ago (gas tank had rusty fuel in bottom - cleaned it out prior to new petcock); when I turn petcock arrow NOT to on or reserve, fuel comes out of line; when I turn it to on or reserve, fuel doesn't come out; puzzling
-I don't know what's on back of fuel pump - it's a valve that has a hose coming out of it - looks like it goes to engine/carb - I haven't traced this out yet - what is it?
-can squirt gas on air filter and engine will run for 2-3 seconds then stop - fuel in top of carb (under diaphragm) does same
-it likely needs carb rebuild - will get to this - but something isn't allowing fuel to get from fuel pump to carb
-I THINK it has a mikuni model x carb - diaphragm is ID 26mm OD 68mm - hard to find inexpensive diaphragm, I guess because it's a model x
-last thing - I replaced solenoid due to old one clicking; I HAVE to be charging the battery or it won't start/turn over - battery just goes dead; but if charging, it'll turn over nicely; i'm guessing it's a bad battery
-any help appreciated - I've never owned an ATV before - inherited this beast from grandparent in-law
By Belmontie
Hi all just started to mount a winch on my kingquad 400 using a kfi mounting plate and the holes don’t line up. The winch is Rhino 3000lb not sure if you have them in the States they’re an Amazon job. I was wondering can I just drill the mount out to make it fit, the holes are fine depth wise it’s just the width trouble is it’s not out a great deal and as the holes are countersunk they will overlap I don’t want a loose winch. Dunno if you can make sense of all that but any help would be appreciated thanks.
By pcumby
Hi guys I'm in the market for a new ATV. I narrowed my choices down to King quad 750 Grizzly 700 and Rubicon 520, I own a 2006 500 Rubicon right now and I like the reliability and power for plowing. However it is not a capable ATV. When quading with other guys it falls short with ride quality and ground clearance. I also have a 500 King Quad 2015 which I like and will keep it for my wife. It is very strong and reliable also. However my plan is to sell my Honda Rubicon and replace it with a 2020 of one of the these mentioned above. Can anyone give me their take on one or all of these machines and why you picked what you picked?
By Rich1028
Suspension Question? Shocks for 250X
I bought the wife a 2019 honda 250X,it does not have adjustable shocks,I'm thinking of maybe getting one as well,for her she does not notice it as much as I do but the ride is not as good as my 1991 250X with adjustable shocks.
So I'm looking at maybe getting new shocks if I get one for myself,I find these.
Elka Suspension
LEGACY SERIES FRONT & REAR KIT SHOCKS for HONDA TRX250X, All Years
$ 999.99
https://us.elkasuspension.com/product/legacy-series-front-rear-kit-shocks-for-honda-trx250x-all-years/
anyone here use these shocks?and how good are they?
Similar Tagged Content
By Guest Fox300exchic
The Hop-Up: You may be saying to yourself, “that’s a chick bike,” and you’re right. But honestly, it’s so much more than that. It’s one badass bike. http://www.quadmagazine.com/quad/features/article/0,24942,1587044,00.html
By Racer944
Hi Folks;
Has anybody on here installed a winch on a 2003 Magnum 2x4? I am using a Cycle Country adapter plate (only one I could find), but am having a bit of trouble getting it all to fit properly, and am looking for someone that may have done this install and/or may have some pics of the installation.
Thanks!
Eric
By katasha2
I took apart the carburator to clean out and I can't remember exactly where the springs that are inside the float are supposed to go I've tried to look up schematics but I think I am missing a spring maybe need helpt:confused::confused:
By skgw1
Feul pump went out. Replaced. At times quad cuts out like its not getting gas. Saw article on new pump needs to be calibrated. Told how to go into a service mode. Does not tell how to calibrate after going into mode. Can anyone shed light on this procedure.
By Bwdeaton
I recently picked up a king quad 700 that doesn't run in the hopes of getting it running by spring. It had been previously taken apart some and a few pieces are missing in the engine, but the frame is complete and in good condition. The motor will need a piston, rings, cylinder, cams, and a few misc parts that are missing. Also the cases will need to be split to remove the pieces of piston that are in the crankcase. The piston blew up at high rpm and did a number on the cylinder so I'm trying to find out if it would be worth rebuilding this motor it buying another engine to swap in. There may be more damage to this engine that I can see so I was wondering how bad the insides of it could be considering it destroyed the piston. I have found a motor for 1200 plus 200 shipping, the only problem is I don't have that much now and I would have to save up a while before being able to afford it. Any suggestions appreciated.
