Hey, for last couple weeks I've had issues posting a reply or posting a thread. Any ideas ??
It's taken me all day just to get this posted ........ HELP !!!
Some people are complaining that they are having issues. What type of issues exactly, is the site slow for you? Login issues?
1. What browser are you using?
2. Have you cleared your coookies
If you could,open a command line in windows
Type tracert www.quadcrazy.com
Copy the output details and PM them to me so I can see your connection.
Anyone having issues, follow those steps.
Its not allowing me to post either ! Everything seems to work on other websites and my personal stuff but not here ??:huh:
But you just posted in the forum, so what exactly do you mean? In another area? On a members page? Can you describe your issue?
ya its workin now but last night when I tried to post the screen would go blank I follow o couple other websites and they were workin fine but when I went to QC it woun`t download it or it would take a long time to load ! then when i went to post it would not post what I wrote But its workin at the moment ! :confused:
Ok, if you have any other issues, please let us know. It's hard to troubleshoot when everything is fine on our end and all tests are ok, but who knows it's possible that there could be a connection issues for some and we need to get that fixed if there is. :yes:
I just moved to Alabama from NY april 1st. We have been fighting Mediacom because our cable/internet connections keep going out for a few seconds. So that might be one of the problems on my end.
Sent from my SGH-T989 using Xparent BlueTapatalk 2
So you are currently experiencing problems?
Well, I've been try'in to make a post for three days now ... no luck !! And NO WAY can I PM you ... the web site times out.
Let's see if this one goes thru ..........
OK, I'm gonna try another post ... and here's the answers to your questions ...
I'm using both IE9 & FireFox, I've cleared my cookies several times. And if this works, here's the tracer results. I've done this four times, & every time, it starts timing out about the 12th ping ... and at the 30th one, it closes.
Password to this photo is GunnyE9
Thanks for posting this. Our site IP is 64.22.110.164 and it looks like you are not even reaching it and its stalling somewhere. Once you reach this site, the last HOP would be our IP. I wonder if Comcast is having an issue. I will investigate. I'd be curious to find out if others are on comcast and having issues or not.
Also since you know how to get to the command line, try flushing your DNS settings by typing: ipconfig /flushdns
Then run the tracert www.quadcrazy.com again.
I suspect a possible DNS issue on your end.
Well, it's still happening. After I made the above post, I was able to go the forum page, but when I clicked on the Picture and Video Forum, it just sat there. I had to close the web page, waited for my computer to go to sleep, and then was able to come back to this page ... now to see if I'll be able to post this info ...
Check your IP at this blacklist check: Blacklist Check
Maybe our firewalls are blocking you? I've added you IP to our lists to not block...let me know if that solves your issue.
Didn't do the Blacklist Check, HOWEVER, this morning, I'm able to navigate the forum like old times.
Made some changes to my profile page, added a couple photo's to my photo page, all with no issues or hangups !!
Still checking other items, but everything seems to be working great. :unsure:
Interesting...sounds like our firewall maybe. To help me more, please verify that you are still surfing without issues. I may ask you to do this again as we see what settings are causing this for you.
So far, everything is working great. I was even able to upload a couple video's just now with no hangups or problems.
Can't seem to get my photo's to change or update on my garage page, but that's no biggie right now. (& that is probably something I'm doing !!)
So all is good. :biggrin:
    • By HeWasRidinDirty
      I rebuilt the carb on said machine. When I hook up the auxiliary gas tank it runs fine and everything is cool. When I put the fuel tank on and hooked up the lines, it completely flooded the cylinder and even about an inch of fuel in the air box. I'm pretty sure that it comes from the little hose on the petcock and hooks to the top of the carb. WTH is that even for? I mean the thing runs fine on the auxiliary tank, so idk And on the petcock when it's in the "on" position, I get no fuel. The petcock from the bike I took it apart and checked out how it operates. The sharpie marks indicate how it really works. Now the other petcock w/o the sharpie marks is an old one that was leaking that I removed from a Polaris quad. It's exactly the same thing, except the small hose and nipple have been removed. I'm so confused, LOL
    • By jeffrocdx
    • By alexwv1863
      I'm currently working on an 04 Suzuki Eiger 400 and ran into some issues. Main issue being it's really hard to start. Once I get it started, it runs bad. Sounds like it's missing, which I'm pretty sure is an idle issue. It's not my 4 wheeler. I'm working on it for a buddy. Someone started working on the original carb and 2 jets were missing when I got it to work on.
      So, I ordered a new carb. To get it to run, I had to adjust the throttle screw on the handle bar almost all of the way out. Even doing that, it still sounds like it's bogging down and missing.
      I did put a gas filter on it, which I'm questioning whether or not that's the issue and it's not getting enough gas like it should. The petcock only has an On, Reserve, and Prime option. It also has 2 ports. I guess I have the hoses hooked up right. There's no way to shut the gas off completely, and also it looks like there's no gas getting thru unless I run it on Prime. Reserve drips gas. I'm going to take it apart today and clean it. I'm also going to take the jets I need out of the new carb and put in the old one.
      I don't know what all this person did you the 4 wheeler before I got it. There's odds and ends missing that I've noticed so far. What else can I try or look for? What could be the gas issue with the carb and petcock? The carb was completely off the bike except hanging onto the throttle cable. The diagram I found for the carb doesn't help me with hose placements. Any help, or questions would be appreciated. I can attach photos if it would be of help.
    • By Sketchy
      I've finally been able to get the plugs to spark by replacing the coils, regulator,  and cdi.  When checking the plugs for spark I noticed that they would spark for only a second or two and then no spark.   I release the start button and try again with the same results.  Shouldn't the plugs keep sparking with the start button pushed?  Thanks in advance.
    • By erkme73
      Just purchased the subject 150.  It makes a crunchy chunky sound when reversing. There was a lot of slack on the chain so I assume that was it, but when I took the chain off I noticed that the transmission output shaft has a lot of slop in it. I have to assume that's not normal. Can anyone confirm?
