Somehow ran my system dry of coolant and didn't know it. Was running with dead battery. i.e. no lights. Overflow hose from filler neck to recovery bottle was melted.
Wheeler is very hard to start after this. Prior; rebuilt the carb and machine ran great. Now I have to slightly hold the throttle at just the right spot while choke is on to get the engine to turn over fast enough to start.
Now once it starts I am getting white smoke coming out where the thermostat goes. I removed while flushing out remainder of old antifreeze and beginning to put in new.
See the video.
Thanks for your input.
[ame]http://www.youtube.com/watch?v=DuBS0R2shII[/ame]
:aargh:
Edited by richclick2010
Bad Link
As for the head gasket, my guess is the cam wasn't opening the exhaust valves enough and so the exhaust pressure had to go somewhere. As for the cam flattening out, I've been told that someone probably ran low on oil for a while.
I'll ask my engine guy once he has looked over the head.
the older sportsman were known to have soft cams the problem is theres only one cam lobe opening 2 valves and if your not on top of setting your valves regularly they tighten up and never give the cam a break(in contact at all time) and wear it out very quickly valve clearance is .006 intake and exhaust...im guessing u lost quite a bit of power for a while up to when all this happend...good luck hope its just the gasket for your sake
    • By Mister907
    • By Brent Wright
