I have a problem. My son decided to replace his battery in a 2007 artic cat 700efi. when he did he got a new battery that was clocked wrong and hooked it up backward red to - black to +. the rectifier mounted behind and under the rear fenders blew apart. I replaced the reg/ rectifier and engines starts but I have a short to ground. v ohm meter between neg cable and neg terminal, 12 volts, Ive pulled the fuses 1 at a time with no drop in voltage disconnected the relays and the ecm, still no drop in voltage to ground. Ive loocked over as much of the harness as possible looking for damage but cant find any. Im just wondering where to go from here.
Got any ideas
Thanks in advance
Rick
    • By LMI
    • By ButchM
    • By tds7
    • By dkgg5755
    • By Kurt Reiser
      My quad will not run with the airbox hooked up  Will not go past quarter throttle as soon as you unhook the tube at the back of the carburetor it runs great  does anybody have any ideas what it could be I have a bad fuel pump one on the way can that cause the quad to run like that
