So we bought three Kymco quads spring of 2017 and put them through the test all summer in north central WA mountains.  My boys MXU 270 surprised the hell out me several times when I thought for sure id have to pull it through some muddy spots but he cruised on though like it was 4 wheel drive(which it isn't).  Really a well built great beginner quad even for younger riders as it comes with the restrictor rings that only allow for about 25mph till they are ready for higher speeds which this tops out at about 45mph which is plenty for mountain trails.
The wife's MXU450i is about the smoothest running, and shifting quad I have ever been on.   Has great pep for a 450 and with on the fly 4x4 she has gotten up every where I've gone(despite my best efforts).  She is only 5' tall and really likes the narrower seat on the 450, something to keep in mind if your considering a 500 as that will put you on the wider body which may not be as comfortable a ride for some.
I really have only have one complaint about my 700i and that it isn't a 1000 :).  Super comfortable to ride and plenty of power.  Rode these all season with no issues what so ever.  To be honest the quality of these machines is definitely comparable to Yamaha, Suzuki, or Arcticat.  The main reason I bought these was the price.  I was able to score all three for about $14,500 after tax as the dealer had been sitting on them for about a year since no one around here wanted to take a chance on an unknown brand which worked out very well for me.  The mxu270 came with decent undercarriage guards and plates but the skid plates on the 450 and 700 are plastic so defiantly replace if your riding in rocky areas.  I made mine out of 3/16'' aluminum using the plastic plates that came on them as a template.  Only took about $100 and a weekend but you can also buy these if your not a cheap as I am.
My friend has  a  Kymco  700 and  loves it..  Yes Kymco  quality is right up there  with   the  Japanese   makes.  In fact  , if you dug  into  it , you'd  find  Kymco  does a lot of  manufacturing  for   other  makes ,  both in   parts and assemblies.   Some  junk  does  come out  of  China  and  other  Asian  countries, but  also  despite what  American  industry tries to tell  everyone ,  some  very  high quality products do  also. Kymco   is a  Taiwanese  company ,  and their  products  take  no  quality  back seat  to  anyone.
Now ,  I can think  of some  American  companies that  can't  make  that  claim  about their  products,f  one  in the  quad  manufacturing  industry . . LOL.  I don't  know  how  common it is   on  newer  ones,  but  up  here  among  people  I  know , older  Polarises  have  the  nickname  " Pull  Hairis"  for all the  problems  they have  had .
  • 5 months later...
Hi I have a 2014 kymco 700i mxu. It only has 1600 km on it and the speedometer and odo stopped working. It just stays at 0kmh and odo does not go up. I’m wondering if it was the speed sensor would the check engine light come on?  I have take. It out and cleaned it but still does not work. A dealer told me the light should come on if there was a problem with the sensor so he thinks it would be the screen. Everything else works on the screen including riding hours, gear position, fuel gauge,clock. Can someone help please before I buy parts for nothing. Thanks
I do not know if this information will be accurate for you but last year I had a problem with my Arctic Cat 366 which is basically a Kymco MXU 375. There is a speed sensor that sends pulses to the POD to measure speed. (Picture 1) I had the same problem, reading zero. First picture is what the speed sensor looks like ON MY QUAD. It MAY be the same on yours?
First thing to do is unplug it, clean it with electroclean (you can find it at any auto parts store) then measure with the ignition on to verify it has power to the sensor.  (picture 3)
I have a meter that can measure Hz and I was able to verify the speed sensor was bad with it quickly. There is another way. Look at Picture 2. With the ignition on take a thin pair of needle nose pliers or use a piece of small gauge wire and go from the +12V lead to the center lead and "tap" it several times. This will simulate the pulses sent by the sensor. If you POD shows a speed reading, the sensor is bad. If it does not. You may have a broken wire or a bad connection to the POD, or a bad POD.
(My meter showed me with the quad running at idle, I had pulses coming from the sensor, but the voltage output was too low for the pod to read)
Mike
So if I tap the leads with pliers do I tap both at the same time or leave on one lead and you said if the speed goes off of zero that means the sensor is bad ?  And if it doesn’t move off of zero it could be the screen?  And yes the sensors look identical. Thanks for the reply
Either way, since I had thin pliers, i tapped both at the same time. (make sure your going from the 12 volt wire to center wire.
If it doesn't do anything, I would suspect the wire first. This quad did have a wire harness problem in the front side. It was intermittently blowing the ignition fuse and I found a rubbed through wire in the front frame. If you have a schematic, you can disconnect the pod and verify continuity between the speed sensor plug and the pod.
Its possible the connector to the pod is dirty and not making a good connection. I would suspect a pod problem last.
Mike
      The 2026 Muddy Creek ATV Motocross National Championship (ATVMX), an AMA National Championship, delivered an unforgettable weekend of racing in Tennessee, combining intense on-track action with a meaningful tribute to one of the sport’s greats, Joe Byrd.View the full article
    • By wilmpie
      hi everybody
      thanx in advance
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By Cactus
      Hello everyone, getting back into ATV'ing after a 25 year break. Hopeing to places to ride and maybe people to ride with in and around Michigan next year.
      Just picked up a CFMoto CForce 1000 Touring for me and my wife. We're kind of leaning towards the national forest campgrounds and trails. Any input is appreciated!
    • Guest Fox300exchic
      By Guest Fox300exchic
      Here's mine...
