Machine ran fine one day, next day nothing. Replaced the coil still no fire. battery is fine, have lights, dash indicators, etc with key on. Cranks over, just no fire.  How do I check the CDI?  Also what is the probability of the stator being bad?  Thoughts?
  • Ajmboy changed the title to 2007 Arctic Cat 400 ATV No Fire
Spark plug could have gone bad, I owned this exact machine, I had a crack in the spark plug boot once, I replaced the coil & boot as one assembly, it was only a few bucks more to replace both.
but change the plug first
Here is the schematic, looks at item 21 lower right corner, that is the stator, the three black wires are the AC volts for the charging system, the other four wires are the trigger for spark. The 2007 400 models were known for wire harness problems.  The service manual is in the link below. You will have to check to make sure you don't have broken wires from the sensor to the CDI. 2006 and earlier models did have an issue with the stator magnets becoming unglued, but this was solved in the 2007 models. I had that machine for 9 years and put 16,000 miles on it and never had a stator problem. I did have wiring harness problems twice. The service manual should have the procedure to test the spark trigger.
Mike
http://www.mymowerparts.com/pdf/Arctic-Cat-ATV-Repair-and-Service-Manuals/arctic_cat_2007_400_500_650_700_service_manual.pdf
Alright gang here is an update!  Finally pulled the case off. Magneto looks great.  4 of the magnets in the rotor are loose and sliding.( Any home grown epoxy fixes?) Other wise new rotor.  The outer magnet has no magnetism at all. How can the trigger work if this is my finding?  Thanks
      any ideas how to correct
    • By Adamb2025
