1987 Yamaha Big Bear How To Test CDI
Big Al
Hello. I'm new to this forum. I just bought this big bear. This thing is show room condition. Now I haven't had time to dig into it so it might be easy to fix. But the guy I bought it from said it needs a CDI box. Now is there away to test these to see if it's bad? I see they are hard to find. Any recommendations on batteries? Any help would be greatly appreciated. I'll get back with results one I get time to look at it.
Well I tore it down and tried jumping it. It turned over for a second and then some buzzing/clicking came from the rear and briefly from the front. I would hate to by that CDI box not knowing if that's the problem. I see some relays in the rear. Just wondering the next steps to getting this thing running?
  • Admin changed the title to 1987 Yamaha Big Bear How To Test CDI
Not necessarily, although that is not completely ruled out. What could be your issue is a lack of a full charge-12 volts or so- to everywhere it needs to go. If the solenoid is buzzing then there is something causing less power from getting through. Make sure your battery connections and other connections are tight and that all your grounds are good too. If a ground is corroded then sand it and see if that helps. Hope this helps.
I just had this starting problem. The hot wire on the starter stud was deteriorated to rust powder. I replaced the starter and it cranks easily now. I too now have no spark. I am not saying the two are connected in any way. Just trying to help and learn...
Hi there, I’ve got a 1990 Big Bear 350cc and was having trouble getting it going. I tried just about everything. I even bought a CDI unit. Well it turned out to be a faulty carburetor. I bought a single cable one and it works great. So…I’ve got an extra CDI unit that I’d like to sell. $150 Canadian + shipping
I’ve also got a completely rebuilt dual cable carburetor that cost me $495 ca. I’d sell it for $300 Canadian
( [email protected] )
I live in BC
Wow. Everyone is all over the place on this.
Great looking bike awesome find lucky you!
The cdi is a working or non working component.  So the fact that it fires up I would say it’s good.
Now since you have all the plastics off and everything is exposed I would take your time and unplug each plug one at a time and clean and add electrical lube and reconnect.
A good eye glass screwdriver allows you to get in and scrape clean the contacts of all the plugs.
after that go through all the wires that are attached with a bolt or screw, grounds, battery connectors and the starter relay .  It’s very possbale that the starter relay is no good and a much cheaper part to replace. Keep in mind the electrical system is big! That means the coil wires, ignition, handlebar controls, regulator etc. do it in sections and move on to the next section.
After all this is done if it still does the same thing it hasn’t cost a penny before you start guessing and buying parts and all bad connections are ruled out.
Put a fresh battery in that baby and see what you got.
Lastly is I’ve had a bad cdi box and one way that it will not perform is if it has moisture inside. Simple stupid way to get that out is to put it in the oven for 10 min on 250! Make sure the oven is on 250 before you put it in and no more then 10 min. Take it out and cool off and try it.
Good luck and keep up posted.
    • By pitts
    • By Werewolf
    • By 86ccord
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By newguy024
