So I finally finished a bike I’ve been working on for my daughter.
Ive been practicing the vinyl thing for a while and making the camo vinyl prints as well as applying them.
This was a bike I dug out of a garage, original owner.
Compleyey broke it down and did my thing to it. So I put a girls touch on it and my 12 yo will be sporting this.
Dont be afraid to say what you think.
    • By HoldenBoy
    • By Asand211
    • By TravisCr
    • By lewisrssll
      View File Thumpstar ATV 70, 125, 250 Owner's Manual
      ATV 70 125 250 - v6.pdf
      Submitter lewisrssll Submitted 10/01/2024 Category Other ATV
