  • Ajmboy changed the title to Honda Sportrax Hubs From Recon?
the bolt pattern is the main issue- as far as I know, atv brands have the same bolt patterns among the models- so you couldnt take honda rims and put in on kawasaki....  But I would say yeah, go for it!  Worst case, you might have to buy some spacers to keep the rims from rubbing your brakes... dont know about that.
You'd have to  measure to be sure , but the hubs  may very well be interchangeable.  My guess is they most likely are if they are from similar  quad series. Hubs  from  a 250cc to  350cc bike in  either series are more likely to be a direct swap than  from a  250 and one with a much larger displacement.  More power would  call  for heavier axles  and hubs in most cases.
  • Like 3
    • By DexKing
    • By J-Dub
      2001 250 Recon randomly shuts off but will immediately fire back up . Any thoughts
    • By Coyote251
      Hello,
      Hoping someone can help me out. Just picked up a 2001 Recon for my son, got a good deal on it but the rear-end of the bike came in a box (pieces). I have gone through and inventoried what I have and what I need but I am not sure what size ring gear spacers I should get. I have a new pinion gear installed and a new ring gear to put in it, all of the other bearings and seals are replaced also. So since this should be pretty much like a new differential, I am thinking that "F" is the right size (1.56) based on the manual where it says this is the "standard" size. I am thinking that I need to start somewhere before I worry about measuring backlash.
      Any input or advice would be appreciated.
    • By vwhobo
      Does anyone have a used set of tires for a '97 Honda Recon pretty close to Sumter, SC?  Not looking for anything new or expensive but they've gotta hold air and have some tread left.  Wheels not needed.  Sizes are 22x7x11 and 22x10x9.  Thanks.
    • By Ironworker709
      Just a shot in the dark here..but...
      Does anyone have the red rear plastics for a 2000 honda recon in eastern Georgia areas?..
      We live in Millen area..it is in between Waynesboro and Statesboro
      My 17 year old grandson has somehow tore ours up and the battery pocket in it is even busted and the battery is hanging now
      Dont much care if it is faded or not..it will be getting rebuilt soon and we probably paint it anyhow
