1992 Suzuki King Quad Too much fuel
By Flash_fella
By Werewolf
By Brantley11
Hey everybody,
Here is where we sit:
New 93 Non Ethanol Gas
New Spark Plug
Bluish white spark
Good Compression
Here are the readings:
By Mhatayas
By Gwbarm
