1983 Honda 250r Parts
First off welcome to Quadcrazy. That’s a lot of money for what you need done.   If your mechanically inclined you can work on the bike yourself and save a ton.  It’s also an old bike so I’m sure you paid very little for it so you don’t want to put too much into it.  YouTube has tons of videos to help you along as well as the members her at Quadcrazy.   Parts are available from eBay or aftermarket.
But again this all depends on how much you can do yourself.
Listen, I’m not sure what your situation is but I can tell you this. You have to make the time if this is something you like to do!
I have enjoyed doing this work/play most of my life. I got married, had kids and all of that was put on the back burner for a long time. As soon as things settled down I had to make the time to do what I am doing now.
Plain and simple this is what I like to do and it keeps me sane.  Not saying it’s for everyone  but you have a good old bike that you can get parts for and you can get the bike back to good. Question is do you want to have a project bike ?
Its very rewarding bringing some back to life.
Quadcrazy has a huge member base to help you along the way!
Make a list, prioritize it and bang it out if this is something for you.
No matter which way you go good luck!
I do enjoy it. But I'm working 7/12's right now and there is no time to be had. That's one of the reasons I wanted to go with a mechanic. I've looked on Amazon and Ebay for parts I need and I just don't see them. The mechanic told me they don't even make new parts for most of my bike. Is that even true? Can you tell me where to find new parts? And the reason I joined here was to be able to talk to ppl like you. So yes... I want to get this thing going. I'd at least like to get all the parts ordered that way when I get laid off I can do it.
    • By pitts
    • By Brantley11
      Hey everybody,
      Here is where we sit:
      New 93 Non Ethanol Gas
      New Spark Plug
      Bluish white spark
      Good Compression
      Here are the readings:
    • By newguy024
      he fifth round of the 2024 ATV Motocross National Championship Series, an AMA National Championship, took place at High Point Raceway View the full article
      he fifth round of the 2024 ATV Motocross National Championship Series, an AMA National Championship, took place at High Point RacewayView the full article
