New Yamaha Rider from Bulgaria
Asen_77
This week a go back to a track that I ride on my first video for my channel. This track is around village that I ride, and now go back just for the Summer season. Here is video from this week
and also my first video - same track on the snow :)
Enjoy! Hope you will subscribe, like and comment!
    • By Brantley11
      Hey everybody,
      Here is where we sit:
      New 93 Non Ethanol Gas
      New Spark Plug
      Bluish white spark
      Good Compression
      Here are the readings:
    • By oxidized_black
    • By Need-help-with-quads
      Can anyone help me?
    • By HSTAR
    • By ResQ91
      Hi guys
      battery and connections good
