2000 Yamaha 400 Big Bear, dies off idle
By Flash_fella
By Brantley11
Hey everybody,
Here is where we sit:
New 93 Non Ethanol Gas
New Spark Plug
Bluish white spark
Good Compression
Here are the readings:
By 86ccord
By newguy024
