Anyone else catch a quad on fire?
Similar Topics
By Wagnerc
It seems like it looses fuel prime after sitting A few days. If you ride it every day it will fire right up. Parked for a few and you have to use either to start it.
By Steve Howard
I picked up this ranger cheap because the AWD wasn't working. I checked it out and had 12.5 volts at the diff if I unhook the ground from the harness and run a straight ground from the frame it engages. What could be causing this? Any help would be appreciated!
By JacobSlabach
I have a gentleman that asked me to service his bayou for him. I have always wondered what oil should be used in atv engines? Pros? Cons? What weight should be used in what type of weather? Is there one kind that I could bulk buy and safely used in any quad I worked on or owned? What about performance? Engine Life? This has always been a 🤔🤔🤔 area for me with quads as far as why you would use one type of oil over another....
Thanks!
By Mezzy
My 2005 Kawasaki banshee runs great, perfect at sea level and starts right up has a great idle perfect performance till I get up to 4000 feet and struggles to start won’t run hardly at all till warm. Anything I can do to the carburetor in a quick type adjustment?
By Quad king
I am not sure what is wrong with my King Quad. I had a new carburetor put in 6 months ago, just replaced the fuel pump and added an in-line fuel filter in. I have been trying to fix this quad for a while now and do not know what is wrong with it. It idles fine and runs great as soon as it is fired up, you can Rev it and stay in first gear with 100% power. As soon as I drive 10 feet it looses all power, I mean it is sputtering and doesn't move at all, but when I let off the gas after it sputters it idles fine. I will attach a video of what it is doing.
Snapchat-1290161440.mp4
