Yeah,,,,,,,I know......Those pics of the indoor Track were taken when I first got that Camera..... I had to go with a Fixed 50mm 1.8 because of the lighting and I dont have an External Flash... All I have for Editing Software is the Cannon DPP which Sucks......
What do you use.......??????
I love taking pictures......But I find myself in AUTO lots of the time because I know if I dont I might lose some good Shots.....Ive been told to shoot in RAW for editing purposes but they all seem Grainy when I go to look at them on the computer.......
What say you????
Taking this to a new thread hence being accused of going OT ;) ;) ;)
-TD
Check General Discussion board........I think I just had verbal diarrhea
-TD
me no comprende
Google "The Lone Ranger"
It's an "old person" thing.......
*URP*
:drool5c:
-TD
Hey tech welcome to the site. I like the one where your on your right rear tire only, purdy cool!
Oh yeah, can I use your wheelie bar that would be the only way I could pull one off on my over weight popo without killin' myself.:laugh:
Fab one up!
I've actually thought about trying to build something that would go in the reciever hitch just so I could play around but it would have to made of titanium, my popo weighs 720lbs without me on it!:huh:
On a different note, I just started at the beginning of the thread and looked at all of the pics and man there are alot of great shots! Makes me wanna go ride right now!
i built the wheelie bar in 2 hours just playin around one day cuz you cant ride my raptor with the front wheels on the ground,...but i like it it, only does about 120 mph right now but its in 100 pieces on my bench right now and when i get it back together..... :)
120 huh?
lol what do you have done?
Sorry,,,,,Im Callin BS:laugh: Unless you can Back that up:no:
Welcome to the Board:confused:
    • By pastorjeep
    • By cruteg8
      hello i am a new member to Quad Crazy i own a 2000 warrior 350 and just bought a Kawasaki Lakota sport 300 with a blown top end
    • By hardcastle
    • By ejtaylor25
      OK long story short....bike was running great no problems and i was back in the woods one day and it stalled .It wouldnt restart ,kept wanting to but it wouldnt.I towed it home.It sat in garage for a week ,i would try starting it every couple days ,it wouldnt.Then one day it fires right up.I kept starting it once a week with no problems.Then after a month same thing just wouldnt start.I but a battery tender on it for a day, then it fired right up,problem fixed i thought.So i turned it off and tried again and it just turns......IM going crazy over this thing,the battery is good.....
      Any help would be super
    • By DANJONESHISTORY
      I have a meerkat50 that has a pedal shifter but no clutch cable.  This seems standard.  However, when the atv is in neutral, the engine revs like CRAZY and will pop a wheelie if I throw it in gear.  While in gear, it has little to no power.  Pressing on the accelerator doesn't do a thing.  If I turn on the choke while in neutral, the engine dies completely.
      Here's what I've tried:
      Replacing the carburetor with a new one.  No change.
      Spraying around the connections between the carb and the engine with starter fluid, looking for an rpm change to see if air was leaking into it.  No change.
      Removing the throttle cable from the handlebar to see if it was too taut.  No change.
      Checked timing-- top dead center seems to match on the flywheel and the cam.  Although this depends on the direction I rotate the engine.  The only way to rotate it without the nut coming loose is to rotate it clockwise.  When I do this, the engine timing seems right.  But there is enough play in the chain that when I let it go slack, it may be out of time.  This is likely normal, and I can't imagine this would be enough to cause this problem.
      Any thoughts on what would cause an insane idle with no power under load?
      I really need help.
