That was my 2nd attempt at hydroplaning. The 1st went perfect, the 2nd my right side got into shallower water and caught ground. That side took off and turned me 90 degrees in a heart beat. Needless to say, I got launched. I never saw it coming.
yeahhh it takes some serious courage....i've wrecked quite a few times trying to get better at jumping....this jump:
the first time I really tried it, I gassed it too hard, and fell off the back when my 400 was standing straight up in the air.....but, i was soo mad that happened, i went and jumped it the next time around 6 times before i gave up:skeptic::aargh::biggrin:
Some graet pics! So your suspension can handle your weight from that high?
LMAO!!!! I was 285 in that Pic....Runnin on Stock Suspension 20 yrs old....It did ok....But those Bigger ones would bottom out.....Now I have Progressive Front Springs and a Marvin Shaw Hill Shooter and Ive lost 35 Pounds so far....:yes:
awesome pics MWKE :) I love jumping, but you're right Scott, I totally have a hard time telling how much to gas it before the big jump...
sometimes it turns out good, and well, others they don't turn out soo great. :)
I got some tiny air with zacs quad the other day :o)
I like to fly.....here is a pic of me on a tabletop....longest one I have cleared so far is just over 70 feet.....have a few tabletops on this track that is 120 feet that I hope to clear in the next trip or two there.
Here is a pic of some trails I made last year that has this one stepup that is fun to play on.
    • By pastorjeep
    • By cruteg8
      hello i am a new member to Quad Crazy i own a 2000 warrior 350 and just bought a Kawasaki Lakota sport 300 with a blown top end
    • By hardcastle
    • By ejtaylor25
      OK long story short....bike was running great no problems and i was back in the woods one day and it stalled .It wouldnt restart ,kept wanting to but it wouldnt.I towed it home.It sat in garage for a week ,i would try starting it every couple days ,it wouldnt.Then one day it fires right up.I kept starting it once a week with no problems.Then after a month same thing just wouldnt start.I but a battery tender on it for a day, then it fired right up,problem fixed i thought.So i turned it off and tried again and it just turns......IM going crazy over this thing,the battery is good.....
      Any help would be super
    • By DANJONESHISTORY
      I have a meerkat50 that has a pedal shifter but no clutch cable.  This seems standard.  However, when the atv is in neutral, the engine revs like CRAZY and will pop a wheelie if I throw it in gear.  While in gear, it has little to no power.  Pressing on the accelerator doesn't do a thing.  If I turn on the choke while in neutral, the engine dies completely.
      Here's what I've tried:
      Replacing the carburetor with a new one.  No change.
      Spraying around the connections between the carb and the engine with starter fluid, looking for an rpm change to see if air was leaking into it.  No change.
      Removing the throttle cable from the handlebar to see if it was too taut.  No change.
      Checked timing-- top dead center seems to match on the flywheel and the cam.  Although this depends on the direction I rotate the engine.  The only way to rotate it without the nut coming loose is to rotate it clockwise.  When I do this, the engine timing seems right.  But there is enough play in the chain that when I let it go slack, it may be out of time.  This is likely normal, and I can't imagine this would be enough to cause this problem.
      Any thoughts on what would cause an insane idle with no power under load?
      I really need help.
