STREET LEGAL - ONE OF A KIND HARLEY DAVIDSON 4-WHEELER $9,500 OBO Sporster 883 bored to 1200cc built into a Street Legal Licensed and Insured 4-Wheeler. It has 400ex front end, 250r Rear end. All chromed out with new black gloss paint. I have a $500 Dakota Digital Speedometer to go with it (needs installed). I also have an extra rear gear and extra set of off-road mud tires and rims. Brakes need to be adjusted, and there's a few other touch ups that will place it into show quality. I haven't started it in a while. Ran Great last run. This bike has over $20k invested in work and time. It will go about 120 mph or more. With the other gear it will go about 60 mph. It rides great on and off road. It brings trophies and turns heads at shows. Shoot me a message or offer if interested. (May entertain trades). I will entertain any offers. This is your only chance to own a Street Legal 4 wheeler. Currently titles and registered in KY.
  • 2 years later...
  • 3 months later...
    • By TomJulio
    • By TomJulio
    • By Olchap
      Thank you,
      Olchap
    • By Matthew Alloway
      What is the best paint for a swing arm. I know powdercoat would be the best, but I am looking for paint type that I can easily do at home.
    • By wjmedic
      Recently rebuilt front end on this Polaris 400. New axles, bearings, seals, control arm bushings, Hilliard clutch thoroughly cleaned and inspected with no damage noted.
      Everything put back to together. Placed bike on jack stands all four wheels off the ground, started in 2 WD switched to AWD both front tires spinning, when AWD turned
      off right front wheel will not disengage from AWD. Checked voltage at connectors both left and right connectors have no voltage with AWD switch off, and both have 12.4V
      when AWD switch is turned on. Repeated turning switch on and off several times with no change in condition. I am thinking this must be something mechanical with the
      Hilliard clutch on the right hub ie. weak spring or stuck rollers on the Hilliard clutch assembly (Is this a logical thought?) any ideas on trouble shooting this before I disassemble the
      right front hub again
