2006 Can-Am Outlander 400 XT Oil presure light is on
Hi everyone,
owner manual
service manual
engine manual
  • Admin changed the title to 2006 Can-Am Outlander 400 XT Oil presure light is on
The oil strainer is on the very bottom of the case, just above the frame member. It can be removed/cleaned without engine removal but you DO have to unbolt the engine mounts, remove the exhaust pipe from the head, and very carefully lift it up. The strainer has 5 bolts (8mm socket). I would also VERY highly recommend removing the decompression weight/spring/pin from the end of the camshaft if that hasn't been done. It's a ticking time bomb, and well known over on the can-am specific (only can-am) forum. I just finished getting mine back up and running. It's easy to tell if that has been done, just remove the valve cover and its right there on the right side (behind the cam chain/gear).
  • 9 months later...
  • 4 months later...
You may clean the oil strainer at the base of the engine case without removing it, but you'll need to remove the engine mount bolts, remove the exhaust pipe from the head, and carefully lift the engine up. Five 8mm socket bolts secure the strainer. Since this is a recognized problem with Can-Am vehicles, it is strongly advised that you also remove the decompression weight, spring, or pin from the end of the camshaft. If it has been completed, remove the valve cover and check the right side behind the cam chain and gear.
Correct,in that if it's the oil,I had a bike a few years back ,when you cranked it up oil light would come on checked everything then one day I cranked it turned off then back on oil light went off.  At this point knew it was a short of some kind traced down all wires found short behind light ,wires had rubbed together and would touch as soon as you started.  Just a note that anything can be the cause behind light on. Like my grandfather use to say hope for the best and expect the unexpected.
  • 8 months later...
    • By JohnnyB
      Greetings,
    • By Mhatayas
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By Spritee1
      not sure where to look next
    • By semicolon
