1993 Suzuki 300 king quad…bogs in gear
By
BuddyLee
in Suzuki ATV Forum
Go to solution
Solved by BuddyLee,
By Ant-Knee
I am trying to rebuild an engine for a '97 Kawasaki Prairie that I recently picked up. There is one head bold that just won't let go. Nothing I do seems to make a difference. I have been putting penetrating lube on it for two days straight and I am afraid it is going to break on me. What is your best advice for getting the sucker out? I have tried a rechargeable impact, a pneumatic impact and penetrating lube.
By Coyote251
By BillR94
Thank you for your time
Bill
By kawasig
