Slipping Clutch on King Quad 300
By quadnut20
Just picked up a 2025 Yamaha Kodiak 700 fixing to do a EPI Clutch mod to it since I dropped bigger tires on it !! Air box , exhaust , and programmer next !ย
By jen
Cannot find out why 12 vdcย 4 (4) commutator starter motor has no power. It will run full speed without load. But with any load will not turn. Repaired broken brush holder and insulated an internal wire to magnet that was bare and rubbing. cleaned commutator segments. Ohm readings while slowly rotating commutator was 1 ohm.ย ย When attempting to runย with load it will not turn and Bat vdc only pulls down to12vdc. Cannot find an internal wiring schematic.ย I can buy a rebuild kit ~$35 but WTH?
By ButchM
Hisun 700 EFI. Replaced TMAP sensor had broken off . Fuel pump pressure 41psi. The only way I can keep it running (and runs fine) is to close off fuel return line.ย
By dkgg5755
This thing came with a cheap aftermarket carb on it the problem I'm having is it won't start with choke installed into carburetor it will start and get run without it installed then bogs out after about 2 min run time I've checked timing , compression, checked valves for proper clearance , also did a smoke test for air leaks found none.ย
By middlebrookgt
I have replaced the cracked stator cover on my non-running 2006 LT-F400F that I purchased recently, checked all the shafts vs the service manual and pics and advice here.ย I replaced missing gears, bushings and washers, made sure that truth marks were all aligned properly, that the shift cam springs felt like they returned properly, etc.ย IAfter installing the new stator cover I checked the transfer lever for proper movement from L-H-R and then cranked it up.ย Happily, it runs and changes gears well in L,ย but it will not shift into H or R for anything.ย I have opened it back up and am going back through it looking for the missing puzzle piece(s) but how can I best check that I have everything right this time before buttoning it back up?
