Yes, ALWAYS !! just at the Attachment areas where the Ubolts ,etc.?  hold it down to the Rack , to provide a Vibration Isolator gap between the Rack & the Moose Cargo box! So it won't cause any rattles ,vibration. etc.
Edited by WeeBee
I have mounted a few of these and what i generally do is get these padding squares that stick on they are made to mont on each corner where it touches the rack im surprised they didnt come with it, like the cargo boxes for cars, if not that get some heavy rubber that wont break down from moisture a lot of padding is not weather resistant, but i like the stick on stuff better it stays in place as you tighten it down. Padding is really not necessary i just like for it to be protected at the contact points.
I have reinfoced Tygon tubing I can sleeve the 'U' bolts. ...? and then wrap Foreman's metal rack with garden hose or adhesive pads.
I have electrical 'rubber tape' .  Not electrical tape but the thick tape that is sticky & thick (the tape used to wrap motor lead connections in the motor "Junction box" (To be modest I did not use the term that is normally used by guys).
If this helps. Michelle's cargo box (a soft box) was going bad, attachment points were tearing off so it needed replacement. I got this metal box from a friend cheap, so what I did was remove the plastic cover on the rack and drilled out 4 holes to slip 4 bolts through. Took some plate steel and drilled & tapped to act as thin nuts. So now the bolts act as studs. Drilled the holes in the box and used knobs to screw it down to the rack. This makes the box removable if needed. I used some thin gasket material around the rack to help dampen any noise it might make, but just from trying to shake it, this sucker is on there solid.
I bought a cheap outdoor floor mat, cut to size and used it for the bottom of the box.
11 hours ago, jen said:
So Mike a girl could use flush mount thread inserts in the steel Forman rack to have easily removable Moose box.
Looking back at the picture you posted of the quad, yeah I see what you mean. The rack is bare (no pun intended) In my case I drilled through the plastic cover and did not have to drill into the rack itself.
If you mean those thread inserts used to repair a stripped out hole, two things. They may not be long enough , hard to tell from your picture, the rack tube may be 1/2 inch or 3/4 inch. The insert would have to be that long. Second issue is the thickness of the rack metal is probably 1/16 inch. Not sure if there is enough meat there to hold the insert in place. Would not be an issue when the box is attached, but when removed, they may slide out.
What you might get away with is drilling and tapping a hole in the rack for the screws, I would use fine thread screws such as 1/4-28 instead of 1/4-20 or use metric screws. Then when you go to screw them in coat them with red loctite.
If in the future you had to remove the screws, heat them with a torch to break the loctite bond.
Mike
Why not use some heat shrink tubing, slip it on over the u-bolt and shrink it for protection? If the u bolts are larger then the rack, the garden hose idea will work.
The tread inserts would, as  you say, weaken his Rack.  I will stick with the 'U ' bolts.   I am away on business but when I get back I'll mount Moose and send pictures.
I want to put along gun case on Foreman (ATV).  I have several plastic "air travel " cases and a couple lighter cases.  I would like to see what others have done.
Arctic Cat sells gun cases that mount on the ATV. Perhaps they can be modified to fit a Honda.
Well being a Cheap--- I would like to use one of my cases   Good idea I'll see what theirs looks like  When I get back to Cottage I'll send a picture. of mine.
  • Haha 1
I got the Moose rear "storage/seat mounted on my new Honda Foreman.  The install package came with four (4) 'Ubolts, & water sealing washers.  However te Forman had plate steel rack in the front of the rear rack and tubular rack at the back.  I had to drill holes two (2) 5/16 in for the plate steel area.  I used 5/16 nuts with 1 1/2 washers (to spread the load on the plastic Moose bottom.   I used the 'U' bolts with garden hose to stop rattling and shifting on the back two supports.
I used Flex Tape washers to seal the 5/16 bolts and the provided water sealing wshers on the back.  All bolt heads were capped with Acorn nuts an ;Blue' thread lock.
mosmt3.thumb.jpg.06d262166e3d9992a2b61bd7ac077e34.jpgmosmt2_Edited.thumb.jpg.ac0e29c70ddcecad252c83af7bef1f4e.jpgmosmt_Edited.thumb.jpg.c91cae421303ed216beead3c07e1ed30.jpgmosmt3.thumb.jpg.06d262166e3d9992a2b61bd7ac077e34.jpg
The u bolts were nickel plated. I used SS bolts and acorn nuts.  Thinking about padding or something inside to hold stuff.   It's big inside.  It will hold two helmets just in case I get lucky...LOL
Thanks, You know I have difficulty seeing behind me when backing up.  Has anyone installed a camera just for that.   It would allso be nice when riding to see the guys behind you.
You can  install mirrors on the handle bars  a la bicycles., but if you want a camera you should be able to fabricate mounts front and rear.  I  don't know of any that would be stabilized enough to  make a camera nearly as effective for rear view  on the move  as mirrors would be.
Oops...never thought about that....Yes mirrors probably best.   I  have been riding today with the Moose.  I think I will install some removal foam Blocks inside to reduce vibration.  I have been using my full face motorcycle helmet maybe the ATV helmets are better.   I should meet some ATV riders later this month on a trail ride.
OK The next dumb question:  what type of gasoline containers are best to carry on Foreman.   I am thinking a one gallon emergency supply mounted on the front rack.  The Moose is big enough but I worry about spilling gas in there. I expect to carry Gasoline on my tailer for evening refills when I am back at camp.
Rotopax makes a 1 gallon version. I have one. They are pricey but they are leak proof and don't balloon up like a normal gas can would. With riding and warmth, it will shake the gas up pretty good. I bought the 1 gallon thinking that is all I could fit on her quad, but I managed to get a 2 gallon to fit.
      Best ATV for Older Riders
      Polaris Sportsman 570 EPS
      Best Reliable ATV for Seniors
      Honda FourTrax Rancher EPS
      Best Features
      Best Premium Comfort ATV
      Can-Am Outlander MAX
      Standout Comfort Features
      Best ATV for Easy Handling
      Suzuki KingQuad 500AXi
      Why Older Riders Like It
      Yamaha Grizzly 700 EPS
      Best Features
      Arctic Cat Alterra 600 TRV
      Key Advantages
      Electric Power Steering (EPS)
      Automatic Transmission
      Lower Seat Height
      Two-Up Models
      Hand Warmers and Heated Grips
      Adjustable Suspension
      Buying Too Much Power
      Ignoring EPS
      Choosing Aggressive Tires
      For most mature riders:
      Final Thoughts
    • By Frank Angerano
    • By sunn
      I have an older 2000 Honda 450 ES which has been a tremendous workhorse since owning it new.  I'm now looking to update neglected maintenance on the machine, looking for advice initially on brake work?
